VAF Forums
-   RV-8/8A (https://vansairforce.net/community/forumdisplay.php?f=6)
-   -   Drilling 7/8" hole in UHMW (https://vansairforce.net/community/showthread.php?t=157599)
jimgreen 02-07-2018 04:01 PM
Next up is making said holes in F-8115 thrust washers.
What method gives the nicest holes? A carpenter's hole saw may not be accurate or pretty.
Couldn't find any reference to this.
wirejock 02-07-2018 04:22 PM
Forstner
I would use a Forstner bit. Whole set from Harbor Fright is pretty cheap.
jimgreen 02-08-2018 12:06 AM
Thanks Larry. Don't have a HF here but will look at mail order.
Will also try out a step drill bit on some scrap
mike newall 02-08-2018 04:08 AM
Home Despot flat whiz bit would work. Make sure the piece is securely anchored else it will tour the shop !
https://www.homedepot.com/p/Bosch-Da...5010/203274429
David Paule 02-08-2018 08:29 AM
Depending on the thickness of the part, a hole saw might work pretty well. You know, one of those things that looks like a cylinder with teeth at the end.
Dave
Mel 02-08-2018 08:37 AM
I've found spade bits do a beautiful job on UHMW. Just feed it slowly.
jimgreen 02-08-2018 11:10 AM
Thanks guys, I'll test out a spade bit first. Path of least resistance etc.
scsmith 02-08-2018 12:06 PM
Where?
where do these thrust washers go? I don't remember making these.
jimgreen 02-08-2018 10:05 PM
They are applicable to the ground adjustable rudder pedals. I don't know about the other style pedals.
They fit on either end of the shaft that the pedals hinge on. It's a strange use of the term as there is no lateral force.
BTW the spade bit worked out great. Quick, easy and I didn't have to buy anything.
