| Raymo |
02-09-2018 03:39 PM |
Originally Posted by 9GT
(Post 1238327)
Nice Ray. What are you using to separate and hold the coil in place? I want something that will not allow the coils to bounce around. I was thinking I would fabricate a split loom out of aluminum with snap bushings or rubber grommets and then have the loom fastened to the fuel level sender cover plate.
I used large, opposing tie-wraps, which is what you see in the photo. One around two tubes with another wrapped around the middle of the tie-wrap between them. You could also use a short piece of rubber tubing in between.
Beyond that, the connection to the tank and wing root fairing do a fine job of stabilizing the assembly. I'm in the middle of my first CI now and will be opening the wing roots for inspection to ensure all is well.
