Page 07-07 step 7
This step calls for dimpling numerous parts of the rudder, which are listed as:
R-00901-L-1 and R-00901-R-1 skins R-00915 stiffeners R-00902-1 spar R-903 R-912 R-00915-1 ribs R-00918 attach strips R-00910 horn brace I believe that the reference to R-00915-1 ribs should be to R-00904A-1 and R-00904B-1 bottom ribs. I can?t find any R-00915-1 parts except for the stiffeners and it seems that the bottom ribs do need to be dimpled. But I am calling it quits for the night and hoping someone will confirm or clear up my thoughts before I put any dimples in the bottom ribs. Thanks in advance! |
Hi Ari
You end up dimpling most of the rudder skins except towards the top. Go to the link in my signature see page 79 of the PDF. There's multiple comment's. also use the hyperlink at step 7 to quickly jump between pg 07-12 and 07-07. Hope that helps. |
My question is on the R-00904 bottom ribs. There is a thread that is linked to on page 07-10 in the PDF, with this comment: "Dimple R-904 pieces.... NOTE Not sure this is an issue anymore. PF." That thread from March, 2014 (http://www.vansairforce.com/communit...d.php?t=110873) was asking about page 07-08 but it is definitely the same question I have. Unfortunately, it has no replies. I've e-mailed Van's to ask about the apparent error in referring to the R-00915-1 Ribs instead of the R-00904 Bottom Ribs. I'll post back here if and when I get an answer. |
Basically every hole in the skin that has AN426AD3-xx rivets gets dimpled except for the ones that say do not dimple. so every piece under gets gets a corresponding dimple.
Hope that helps |
Van's got back to me just now and confirmed that this is a misprint. The instruction should refer to dimpling the R-00904 bottom ribs.
The plans for the most part are pretty good. In some places not so great. Overall they're at least okay in my opinion. I recommend reading far ahead before doing much work.
Here's one example: Page 10-11 step 7: prime the F-1037B and F-1037C battery angles as desired. Page 10-12 step 4: prime the F-1037B and F-1037C battery angles as desired. Ok, so two coats, or is the second in case I decided against priming, then changed my mind on the next page? :-) Read slowly, think about what you're doing, and good luck. |
With some thing as complicated and sequence sensitive as building an RV-14, there is bound to be an error occasionally (but they are slowly getting corrected as builders point them out) Very few have been issues that would prevent someone that is thinking about what they are doing, from getting a correct result (as in this example). Read slowly and think is very good advice when building something of this complexity, and I think the prelim sections of the plans recommend reading through an entire section before beginning, to gain some situational awareness of what is coming. |
Interesting that you posted this in Feb 2018 - I received my kit in July and have come across this misprint. Van's still hasn't fixed it but thanks to VAF I have my answer on a Sunday! I just wanted to say "Thanks" for posting your findings - it saves many of us time.
Perfect timing.....Just got to this step a few days ago and remembered this post....
| All times are GMT -6. The time now is 03:39 AM. |
