VAF Forums
-   ADS-B (https://vansairforce.net/community/forumdisplay.php?f=113)
-   -   Uavionics echo / sky power up time (https://vansairforce.net/community/showthread.php?t=157299)
donwmack 01-28-2018 08:34 AM
I connected the echo/sky units yesterday. I waited 3minutes for the WiFi to appear. It never did. How long does the unit take to show up? I did verify power and ground to both connectors. I?m using the navworx cable they sent.
RONSIM 01-28-2018 09:39 AM
Comes up very quick
Will be "Ping" something or other on your phone --
donwmack 01-28-2018 09:50 AM
I was waiting for something starting with ping... on both my phone and iPad and it never showed up. I was asking if anyone knows about how long for it to show up.
RicoB 01-28-2018 10:01 AM
Can you see if the little lights are powered up? My comes up right away!
painless 01-28-2018 10:06 AM
Sorry if this is a dumb question, but did you go to settings in your iPhone and/or iPad and select to connect to the “ping” network in WiFi settings?
Make sure the Echo WiFi software is up to date as well.
https://www.uavionix.com/support/echouat/
DennisRhodes 01-28-2018 11:41 AM
Should be available to connect up to wifi within 1 min if you have powered up the echo and can see the appropriate indicator led s on the Echo. As stated above, the wifi will be named PING XXXX .
donwmack 01-28-2018 11:51 AM
Didn?t see any lights either. Thanks. That helps.
DennisRhodes 01-28-2018 12:16 PM
Put one in a RV 7 couple weeks ago that actually had a bad connector and or wire crimp in the black plug and was not powering up unit. May want to check that if you have NO LED indicator lite.
donwmack 01-28-2018 12:21 PM
Thanks. I didn't see lights on either unit. I did check the wiring to ensure I had power on pin 2 and pin 1 was grounded on both units.
DennisRhodes 01-28-2018 12:40 PM
Actually uAvionics swapped the Echo out for me no questions ask and sent me a new one. Plugged it into the OLD ( original plug ) and had same problem . Pulled out the old black plug and installed the new one ( with the replacement unit) and all worked well . I would bet the original echo would work had we just replaced the plug. I didn t do autopsy on the OLD plug but that confirmed for me something not connected internally.
