Buying an RV10 vs Building questions
I am looking at an 2009 RV10 for sale that is 99% of what I had planned to build. I mean it is darn near perfect match - Paint scheme/color, panel, interior, engine, etc are all exactly what I would do (if not much better in some cases). Low time plane in the 500-600 range. Flown often and IFR. The price on this plane is 200K which when I pencil out building my own RV10 with the QB kit, without some of the massive upgrades the guy did on this RV10 for sale... 200K would be the minimum I would expect to spend if I were to build my own RV10 with the QB kit, and it would not have all the upgrades and updates this other guy did! I would say this particular RV10 for sale should be listed at 250 with all the upgrades and updates done to it. I am tempted to buy this plane site unseen but I wouldn't do that. Would get PreBuy and inspect first.
What say the RV10'rs here? Also, would I be able to do all my own maintenance and repairs even though I did not build the airplane? I would assume inspection required by an AD? |
If you want to fly, buy. If you want to build, build.
Sounds to me like you've found the near perfect airplane for yourself. I would not hesitate to consider purchasing this aircraft, Of course upon passing a comprehensive pre-buy inspection.
As said before, you can do any and all maintenance and/or modifications to an experimental amateur-built aircraft. The only thing you can't do is the condition inspection. That must be done by an A&P or the licensed repairman for that particular airplane. |
Not a 10 guy, but . . .
I wanted to be a builder, I became a buyer, I have had a lot of fun maintaining, modifying, and doing condition inspections (under supervision) on my plane. Give them a fair offer contingent on a pre-buy inspection by a respected RV guy, and let the adventure begin. You will be happy. |
Welcome to VAF
Kent, welcome aboard the good ship VAF:D
Sounds like you have already made up your mind, and are just asking for our "permission" ----------- OK, I give you permission, GO FOR IT!!!!! |
RV-10 decision time
If I had to do it all again... which would put me in the same scenario your in.. I would probably build. I loved building the plane. I also dont let anyone touch my plane (for maintenance) because I am a little paranoid of "human error". I just dont trust the great work of another builder nor would a "perfect" plane be perfect to me until I completely redid it,"my way" and knew it was safe for my family. (there is a lot more to this than the statement ;-)) which, technically, I couldnt since I didnt build that specific plane. But if none of that matters to you, buy the plane, you will absolutely love it. I have flown many beautiful planes but none have ever given me the enjoyment of my -10.
So if you're a avid builder and want to have the pride of creating a beautiful sample of a -10, build, you'll be able to assure that its safe for the family and know every nut and bolt torque, but otherwise, why wait? get a perfect sample of what you would spend over 1000 hours building (not to mention reading and researching) and about 4-5 years and consuming your life to the project, by buying one already completed to enjoy!! Whatever you decide, its a win-win!! Best of success deciding, or, check out the plane and see if your heart says buy it!!, otherwise you'll know you want to build it! |
Get a knowledgeable person to do a prebuy and then if it checks out, you'll be set.
I saw an unfinished RV-10 that someone had bought without that. They did a fair bit of finishing work and bought all the systems, engine, prop, avionics, etc., and then discovered that the airframe was unusable. They took a beating. Dave |
I was the one who inspected the RV-10 that was mentioned above. I felt horribnle for the 2nd buyer, a first-time want-to-be builder who bought it without a prebuy inpsection. It was a huge loss, both financially and emotionally.
Vic |
| All times are GMT -6. The time now is 02:59 PM. |
