Pmag Ignition Harness
I am about to build the ignition harness for my dual Pmag equipped parallel valve O-360. I know that the NGK plugs that are recommended, BR8-ES, are resistor plugs.
What type of wire is used? I would think that we should avoid the wire core wires, because of RFI. I see 7MM and 8MM wires available. Which is recommended? Thanks |
Pmag wire
I got Wire , boots and terminals and pliers from Brad.
I changed my wires out because we wanted blue wires to coordinate with the engine and airplane paint colors. Yes, I know my OCPD is showing :rolleyes: |
Ditto........
Not worth the grief. Let the guys who do this time and time again do it for you. No shorts, no tracking and they fit first time. :D |
Resistor wire is what you want, and that stuff is available in bulk in a myriad of colors and diameters from any online auto parts house. I typically get my supplies from Summit Racing.
You are certainly right to be cautious about RFI. Pmags do not handle it well, and the only malfunction I've ever had was because I installed non resistor plugs. |
| All times are GMT -6. The time now is 03:12 PM. |
