Vans stall warning
Hi All Just a quickie, is it possible to wire Vans stal warning into the Dynon Skyview Touch? Thanks in advance.
Side note - on the last two project the stall warning was not installed and the stall warning slot glassed over as I found the SkyView AOA audible warning to be far superior. No reason not to do both - other than catching your pants on the stall warning vain. Carl |
| All times are GMT -6. The time now is 04:49 PM. |
