Thank you sir!!
Figured some might like a prep on vinyl
I wrapped the entire plane, fiberglass parts and all and have been very happy with the results. Cost about $1950 in material. I used Avery on the plane as a test subject I used 3m1080 on my truck cap had it outside, in The elements of a brutal winter and I am just now noticing some lifting around the rear window on the truck cap. I even used primer/ adhesion promoter in this area. So that doesn?t make me too happy. Probably about a line 8 inches long, 3/8 to half inch wide. Lifting on both sides. |
| All times are GMT -6. The time now is 05:57 AM. |
