49-12 Rev. 3 Step 5 Confusion
I searched and found no problems with 49-12 and yet I cannot mount the oil cooler. I installed the K1000-08 nut plates as directed. The AN525-10R10 screw does not seem to fit into the nut plate. Perhaps I have the wrong screw. OR
the K1000-08 nut plate needs a #8 screw the AN525-10R10 is a #10 screw Not sure what is going on here. Should an AN525-10R10 screw work with a K1000-08 nut plate? Thanks, Jeff |
Jeff - I looked at my plans and the nutplate shown on both version 2 and 3 of section 49-12 show the nutplate in question as a K1000-3 and not a K1000-8 you are referring to.
![]() ![]() I appear to have version 3 of 49-12. |
There must be something wrong!
This is rev 3 ![]() |
Just my luck. I apparently have the Star Wars Tie Fighter plans from an alternative universe.
This makes me lose confidence in Van's document configuration control! :mad:
Mistakes happen. The plans are written and updated by humans..... The couple of minor errors that have popped up in the past couple days have already been noted and will be corrected. Not intended as a defense, but my suggestion is to brows the RV-12 forum for the past couple years and see how many complaints about plans errors you find that ended up being legit errors (I think you find that the majority of the time someone points out the persons error in understanding rather than confirming that there is a plans problem). |
That is a harsh critisizm in terms of salemanship imho. I didn't mean to imply Van's in not doing a good job in documentation, in fact Van's engineers are doing a great job. I tried to emphesize that configuration control could easily catch this. May be I picked the wrong emoji and I apologize for this. I follow your posts in the forum closely and find them very helpful. I am actually a big fan of your enthusiasm and your approach.:) Finaly, thanks to Van's bringing this design into the market! |
:D |
The only reason I mentioned looking through the forums was to indicate that errors in the plans have gotten to be few and far between, so yea, I guess I feel that one error popping up every once in a while doesn't really justify stirring up the idea of loosing confidence in the documentation configuration control, unless someone thinks that having such things in place means absolutely zero errors;) |
| All times are GMT -6. The time now is 05:52 AM. |
