Advice Needed
So I botched the flap spars on my -8 and had to order new ones. That was after I final drilled them to the skins.
My question is should I redrill the flanges to the skins or just run a drill through the prepunched holes on the spar flanges then dimple/csink etc and move on. My concern is if I redrill them to the skins it will enlarge the holes in the skins. I hope that with the prepunched holes everything should just line up if I just run a drill through the prepunched holes on the spars. Thanks in advance. |
Use a reamer, then check the flaps for straightness. If they are true, I'd say good to go.
| All times are GMT -6. The time now is 03:52 PM. |
