VAF Forums
-   Engine Monitors (https://vansairforce.net/community/forumdisplay.php?f=58)
-   -   Flight Data Systems T-30 Tach ?? (https://vansairforce.net/community/showthread.php?t=155770)
Larry DeCamp 12-04-2017 12:06 PM
Does anyone have a Pirep on this tach with Pmags ? I have tried MGL RV1 and EICommander and both were unstable in the last digit at cruise and the MGL wont read below about 1000 RPM. I will buy a T30 tomorrow if it is stable. Just a thought, perhaps the gear lash in Pmags, documented by Bill R, is the culprit and rock solid readings are not achievable ?
JimWoo50 12-07-2017 09:59 AM
I like mine
Way better than my previous set up w transducer and steam gauge which fluctuated sometimes wildly. Still fluctuates a little but I thinks it?s normal 20-50 rpms. I have a pmag and a Slick install was easy. Good value too for the $160 or so.
Bob Martin 12-07-2017 10:08 AM
Works for me
Have it installed with 2 pmags....per instructions.
