VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   Ignition switch center ground (https://vansairforce.net/community/showthread.php?t=155617)
rv8gibbo 11-29-2017 03:29 AM
Hi Guys,
I'm wiring in my ACS A-510-2 ignition switch and the wiring diagram shows the center ground wired to the nearest structural member, but bob from AeroElectic states that , "p-lead shields should
be grounded to the airframe/engine only at the engine end. The
shield is used to provide a ground for the "GRD" terminals at
the switch but no other connection to the shields should be
made at the instrument panel end". Should or shouldn't I ground at the switch?
Cheers
Gibbo
Jesse 11-29-2017 05:53 AM
You can do it either way, but I run that terminal to airframe ground. I do not connect the plead shield there. That wire is used to ground the pleads when the switch is either off or in the single mag position (grounding in this case just the other mag).
rv8gibbo 11-29-2017 01:46 PM
Thanks Jesse, do you ground the shielding at the engine end?
Jesse 11-29-2017 05:39 PM
I do ground the shielding at the engine end.
rv8gibbo 11-30-2017 12:42 AM
Thanks Jesse
bkervaski 02-22-2018 11:02 AM
I'm hooking up my mags today, using 18 gauge shielded single wire, stranded. I have two slick mags. Using the ACS A-510-2 switch.
On the mag side: 18 gauge to each mag, wire on the p-lead, shield to the GND screw.
On the start switch side: wire to R or L respectively, ground to airframe (not switch ground).
Seems easy, am I missing anything? Any consideration for the impulse coupler?
Thanks for any help!
Jesse 02-22-2018 12:07 PM
If you have a single impulse coupling, then install the jumper between the Right position on the key switch and the Gnd position right next to it. This will kill your right mag during start so your left mag will start with the impulse coupling.
bkervaski 02-22-2018 03:38 PM
Thanks, Jesse! :)
