Catto 2 blade 160 knots TAS with new O320D2G
I have about 15 hours on my new engine from Vans which replaced a rebuilt engine the RV-9A airplane had when I purchased it in July 2012.
Yesterday I think I got the most out of the combination at 8000 feet, 2700 RPM, 160 knots true for the first time in straight and level flight. The engine has been performing well and I have no oil leaks. This engine is also equiped with dual PMAGS. I also installed the Antisplat oil separater-positive crankcase ventillation and I can report only adding 1/2 quart of oil so far during the break in, and absolutely no oil on the belly. This while running the engine at 7 quarts on the dipstick. This product has several benefits in my opinion. I am very happy so far with the results. It has the bypass check valve also. I also installed the PlanePower backup alternator on the vacuum pump pad to compliment the primary PlanePower alternator. This was an easy installation and it works perfectly. I can shut down the primary alternator in flight, and the backup takes over automatically and powers the dual Dynon SkyView with GTN650 avionics at a slightly less voltage of 13.6 volts. I?m very happy with this capability and redundancy. |
Sounds Like a Great Setup
On my 2004 build, I paired the O320D1A with the Vans recommended Sensenich prop. It's been a workhorse, but the prop is RPM limited and the mass is such that I can't really get over 2600 RPM except going downhill. Hence I can't develop full HP or get the speed you're capable of. On the other hand, it's still pretty darn good. I need to look into the plane power backup alternator.
Fly safe. Terry, CFI RV9A N323TP |
160 kts on 160hp is moving on.
And i thought my -6 with 160hp catto 3 blade was slow. I get 160 ktas at 8000ft turning 2670rpms. I guess it is normal.
RV-9A top end
Doug |
Yep
That's about where I'm at in level flight all in but I'm running ~180hp.
Pmag ignition timed 5deg ATDC so lost some hp there. Got 196 mph TAS level flight once in smooth air and under 1600lbs. Quote:
A 9A with a 160 HP and constant speed will do 195mph as Van listed. Could do it with my old one after new cylinders but it took awhile and mine was faster at 2650 than 2700 I guess to optimize the CS propeller bite to the thinner air up there at 8000'
realistic cruise speeds?
vans states 162 knots (187mph) cruise at 75%, 8000ft, fixed pitch prop, 160hp engine.
(Q: what RPM setting would this 75% expected to be?) how many can match these RV-9A speeds with their configuration? (I am guessing the cato prop should be about as fast as the sensenich, right? what are they using when they quote this?) looking over past posts, 145-150 knots in their config seems more common. I am wondering what builder mistakes could possibly consume 10-20 knots. /iaw |
My goal is to gain about 5 knots, and I am slowly working on the free things I can do to get faster, first. I am going to re-check my wheel pant alignment at next annual (ball is perfectly centered, but they could both be off...), and am working on sealing up the canopy and empennage. Am also considering experimenting with cowling exit area, as I think it is way bigger than it needs to be now. Realistically, though, I know I am limited with my prop because of the 2600 RPM limit- it will never be able to develop full rated power with that restriction. A Catto prop is probably in my future at some point. My engine won't do constant speed, but neither will my wallet. Tinkering with other things keeps me busy and happy though. Chris |
| All times are GMT -6. The time now is 12:17 PM. |
