VAF Forums
-   RV-12/RV-12iS (https://vansairforce.net/community/forumdisplay.php?f=73)
-   -   Which Rotax engine for your RV-12iS fuselage? (https://vansairforce.net/community/showthread.php?t=155049)
rv9builder 11-08-2017 10:05 AM
I received a notice from Van?s saying they need to know what engine I?ll be using before they ship my RV-12iS fuselage kit. I?m still on the fence on this. I like that the 912iS has fuel injection (no carb floats), better climb rate, and better fuel economy. But lighter weight and a $5,000 savings make the 912 ULS attractive, too. Which one would you choose?
Thanks!
gasman 11-08-2017 10:23 AM
If you were building a house, would you go with tile or granite counter tops?
Look at it this way..... California is going to charge you $1000.00 more than that in taxes when it gets registered.
Larco 11-08-2017 11:20 AM
It might depend on what resale value means to you?
Mich48041 11-08-2017 12:05 PM
The iS has a larger alternator, if that matters to you.
XOverZero 11-08-2017 12:37 PM
Mark, let's talk. I'm on the same fence.
skydiverlv 11-08-2017 01:18 PM
If you were purchasing a new vehicle, would you consider archaic pre '70s engine management? You are getting more than fuel injection with the 912is.
One day, Rotax will not even offer the ULS new, as a complete assembly.
Get in on cutting edge technology!
rjtjrt 11-08-2017 02:44 PM
Resale value would be a consideration for me.
DaleB 11-08-2017 02:54 PM
Been flying a 912ULS equipped RV-12 for a couple of years. If I were building one now... I dunno. The extra cost and that expensive battery with a short history don't give me warm fuzzy feelings. But the extended range... that night do it for me. I do love efficiency. Even if it might actually never pay off in terms of fuel consumption, I've needed to stop for fuel 30-45 minutes short of my destination a few times. I'd love to not have to do that any more. And yes, you'll probably get that $5K back when you sell.
rgmwa 11-08-2017 03:29 PM
I'm happy with the ULS, but if I was building again I'd choose the iS. The extra cost will translate to a higher resale value, if that's a concern. My only hesitation would be the scarcity of trained and knowledgeable Rotax mechanics over here and the number of SB's I've seen for the relatively new iS to date, although both situations will improve over time. The ULS still gets its fair share of SB's too.
David Paule 11-08-2017 03:35 PM
Personally, my impression is that there are enough overall improvements, airframe and engine, to make it a worthwhile choice.
Dave
