VAF Forums
-   RV-14 (https://vansairforce.net/community/forumdisplay.php?f=109)
-   -   RV14 Aerobatic Entry Speeds (https://vansairforce.net/community/showthread.php?t=154415)
sheldon957 10-20-2017 01:22 PM
I have a decent amount of aerobatic training in a Super Decathlon, so I am interested if anyone has any recommended entry speeds for the RV-14 for basic maneuvers?
I own N214PS, (RV-14A) and have about 25 hours in it so far. I have flown wing overs, Aileron Rolls, stalls, spins and attempted side slips.
First observations and comparisons to the Super D:
Aileron Rolls: It rolls MUCH quicker than the SD. Not quite twice as fast, but close. I believe it is somewhere around 2.5 seconds compared to 4+ for the SD.
Stalls: All very docile, better handling than the SD, less likely to drop a wing tip. No bad habits either power off or power on. I have only spun it 1-1? times. Easy to lose 800-1000' for 1? on my first efforts with a 2G pullout.
Spins: Willingly enters the spins equally to the SD, easy recovery, HOWEVER it gets speed in a hurry and loses altitude quickly. WAY more than the Super D.
Wing overs: Flies them normally. I am better at them in the Super D so far, but I have way more experience in it.
Side Slips: I can't make it work so far. I can side slip the SD like crazy all the way down to over the numbers. Maybe it is the extra drag on the SD that makes it work so well. I bank the 14, put in full opposite rudder and it stays normal side slip attitude for 1-2 seconds and then starts turning. I will have to work on it some more I guess. Anyone have hints on it?
rvbuilder2002 10-20-2017 02:04 PM
A side slip involves a balance of aileron and rudder input.
If it turns in the direction of the full rudder input then you aren't inputting enough aileron or you are using too much rudder for that amount of aileron).
If it turns in the direction of aileron input, then you have to much aileron input for the amount of rudder input.
sheldon957 10-20-2017 02:06 PM
Thanks Scott. I'll work on it again for sure. Maybe too much Site Picture/muscle memory from the Super D interfering.
TimO 10-20-2017 07:59 PM
I'm having good luck with many of the maneuvers with entry speeds around 165kts. I've tried a little slower, but not a lot slower. Would love to hear how others are doing with theirs as well. I should note that for the Split-S, I definitely do NOT use that speed...something more like 95kts is more where I have been shooting for lately. I started out with them too fast.
sheldon957 10-21-2017 04:15 PM
Tim,
Thank for the info. Just for clarification, Did you intend to use Knots & not MPH? I do notice that the 14 picks up speed very quickly on any down line. Do you cut back on the throttle, say for the Cuban 8, hammerhead, loop or humpty?
Loved your video's by the way. Very nice to have your daughter solo in it after helping build it!
TimO 10-21-2017 09:14 PM
I haven't done a hammerhead, and I guess I'm not familiar with what a humpty is. I do only use Knots. It does pick up speed very quickly anytime it's headed down, you have that right. I had a friend botch an aileron roll at 120kts or so and turn it into a split-S....we were at VNE and 4.1G's on the pull out as I recovered for him and I didn't waste any time. (Vne the way Van's means it...TAS. Indicated we were something like 186kts). I would rather not do that again.
I did cut the throttle back after the top of the loop, and that dropped the nose and gave slower speeds on the down side, but from the ground the wife didn't like hearing the engine backfire like it tends to when you pull a lot into of power off, so I've been only slightly reducing it now. I would say reduce it maybe for the first few and then reduce it less as you practice. I generally am only in the 120-135kt range when pulling out of the loop on the way down, they way it's been working for me now. For half-Cubans I don't pull back much, mainly because I tend to pick up speed and then pull another maneuver once I hit the target speed.
Some day maybe I should do a video and see if I can document some flight parameters on video, or from the log monitor. I haven't done a video for a while now...but I'm getting itchy to do another.
For the loops, BTW, and your mileage may vary depending on if our g meters match up or not, but I find around 2.8-3 on the pull seems to work well for me. I was expecting more but I don't use the 3.5-4 that I sometimes read about.
Thanks on the note about my daughter. I'm very happy every time I see her fly. She hasn't flown the RV's for a month but I took her out in an arrow to show her what a heavy controlled retract feels like. She did well but says it makes her feel like she's driving a bus. Our RV's are so much more fun....if only all pilots got a chance to experience the beauty of a plane that Van's designs.
mike newall 10-22-2017 05:09 AM
If you use all the published speeds for the RV7/8 you will be in the ballpark.
Top tip - unless you have at least a half Raven, make hammerheads at 85? not vertical else your belly will be wet :D
Also, if you do not have FI, make them less spirited else your motor will stop :eek:
Yep, that really got my attention just before I put the rudder in..... pushed forward instead and descended through a miasmic haze of oil :(
TimO 10-22-2017 11:51 AM
Do you have a link to those published speeds? I don't think I've ever come across anything published.
luddite42 10-22-2017 12:52 PM
You can do a loop at whatever G will get you over the top without whip stalling. Not much of a loop, but unless you're attempting to do actually do them round, then they are just varying degrees of a cursive 'L'. You won't do a round loop at 3.5G either. Takes a little more. 99% of RV aero pilots have never come close to a real round loop anyway, so don't sweat it. And don't sweat other entry speeds either, it just doesn't matter except for snaps and split S's. 99% of RV aero pilots don't do snaps either, so forget about that. Use whatever works and gets is done. There's a very wide range that works for the basic maneuvers. Unless you're trying to fly to some sort of precision standard, it's just wallowing around for fun.
spatsch 10-22-2017 01:37 PM
Here you go:
Loops, Horizontal Eights 140-190 MPH
Immelman Turns 150-190
Aileron Rolls, Barrel Rolls 120-190
Snap Rolls 80-110
Vertical Rolls 180-190
Split-S 100-110
I have no first hand experience in a 14 but if it is anyway like an 8 I agree with Rick it doesn't really matter to much unless somebody is scoring you. I rolled my 8 at 90mph and 200mph and it goes around at either speed. Loops I manage down to 110mph slower I fall out on top. If it's just for fun leveled cruse speed is a good starting point. No reason to dive or speed up in an RV. Also fun to start with loops let's say at 150mph and go slower in 5mph increments until you fall out. Teaches you a lot about how your airplane handles.
FYI the best book on the topic I ever read is Better Aerobatics by Alan Cassidy. Even walks you through debugging your mistakes.
Oliver
Jake14 10-22-2017 05:27 PM
If Va for the -14 is 169 mph I guess that means we don't deflect full aileron in a 190 mph roll?
(VA is the maximum speed above which full application of any single flight control will generate loads greater than the aircraft structural limitations)
mike newall 10-23-2017 04:29 AM
If you want another book, look at this. Very well written and easy to read. lots of common sense.
https://www.pooleys.com/shop/pooleys...on-eric-muller
It will be available somewhere in the States.
sheldon957 10-23-2017 09:24 AM
To Everyone : About your G meters:
Does yours start at 1, or start at 0? Technically, I know we are at 1 G, but I am used to having the G meter read zero, and then show how many MORE G's were applied.
So if for example you said you used 3 G's, was that a true "added on" G reading, or a "1 plus 2 = 3" reading so you really only pulled 2 additional G's.
luddite42 10-23-2017 09:31 AM
G meters have three needles - real time, max +G recording, and max -G recording. It's not a matter of "where it starts". Zero is just one of the values in between the positive and negative numbers. The real time needle indicates the amount of G on the airplane at any given moment. The recording needles indicate the G "history" until you reset them.
pmshep 10-24-2017 06:59 PM
Sheldon, Glad you are enjoying the 14..... Please consider what we discussed about duel aero
in an RV, they are very different than a Decathlon as I'm sure you have figured out ��
Stay safe- Paul
