Where to buy a P-mag
I have called e-magair twice and left messages. Never heard back..
where can I buy them? (the complete setup, gear, spark plug adapters , wires) Thanks! |
Aircraft Spruce
If you need a gear you can get a huge discount if you purchase it direct thru Emagair when you bundle it with the PMag. They have some sort of special deal with Lycoming to be able to do this.
I am trying to buy from them. But I guess it has to be via phone call and I have called twice! No luck getting someone to return my call
Keep calling
If you want to buy from Emag......keep calling and leaving voice mails.
They will answer eventually. I had the same issue around Oshkosh....while trying to order. Once you get someone on the phone they are very helpful. |
Yea I'm still awaiting an answer to an email I sent last week - I wonder if they / their employees were affected by the hurricane?
Don't forget the clamps
If you are replacing a Bendix mag, don't forget to order the two clamps that hold the Pmag to the assessory case. I think they are included in the "install kit" from Emagair. I just installed a Pmag before going on a x-country and had to get those clamps over-nighted when I realized they didn't come with the mag.
If you're replacing a Slick mag I'm told you can use the same clamps used with the Slick. I ordered from Spruce and all was good except for the clamps. I had a problem getting my timing set right because I had inadvertently positioned my flywheel at the wrong angle when changing my alternator belt. People at Emagair were helpful; even on a Saturday, in getting me going. John |
waiting
I emailed them a virtual order and never got a response, but did get emailed info on the shipping and receipt, etc. So they do use it. |
I am still confused on which mag to replace. i thought i decided to keep my impulse coupler one but than when i spoke with someone from Emag he suggested to repalce the impulse coupler one with the Pmag. I am on top of the wall and don't know which side to jump. both ways have pros and cons!
Heeeelp. |
| All times are GMT -6. The time now is 05:17 PM. |
