couple of fueselage questions - help please
hey all
does anyone have a decent illustration of the 6111 skin reinfrocement ribs in place or advice on the method used to cut and form them? one more question. i notice the manual would have me fix the baggage floor down permanently in another step or two do i not need this open to pass wiring to the rear of the fuselage? or at least create a chase through one of the bagage floor ribs between 705 and 706 for later wiring? is this one of those spots not well addressed in the manual or is there an alternate route used by most for the wiring that has to reach the rear of the plane thanks in advance |
Adam
You will want to use under the baggage floor area for a lot of things. I used plate nuts instead of pull rivets on the baggage floor so I can get to the transponder antenna and strobe control box. Most of the wire that goes to the back end can be run under as well. If you are going to use pull rivets, wait as long as possible before doing so. My 5 nickel ( we don't use pennies anymore) Carr |
thank you Carr
So you recomend drilling a hole and using a bushing in the bottom of 705 and 706 between baggage floor ribs for wire passage later? |
Pathway
You can but be sure to refer to Vans locations for snap bushings.
I went with removable floors and baggage bulkhead so I could use that area any time without drilling pop rivets. You don't know, what you don't know. |
Larry
Thank you How would one route their cabling if not through this a baggage floor? I don't think the center space with the pushrods is a good option Why not a conduit through this space and close it permanent? Is there a reason to use this space to Mount anything component wise? |
Not yet flying,
but I ran some of the same black conduit I used in the wings. Ran two sections, one in each side of the plane under the seats and baggage floors. My friend (whose plane is flying) , ran both sections of conduit on the same side of the plane.
I did not use nutplates on the baggage floor and wished I had, it would have made many things easier. I did run wiring down both sides of the center section "tunnel" area. I riveted small nylon tie locations on either side so I could secure the wiring bundles.
There is probably a zillion RVs with conduit run under the baggage floor. some have used the 5/8" drip system tubing from the hardware store. Make it long enough to end in front of the seat pans.
I riveted the baggage floors per the plans and have never regretted it. No conduit goes through there.
My wiring hugs the sides of the center tunnel via Adel clamps. |
Pathways
Yes, lots of builders use the spaces for equipment or terminal strips. Devices seldom accessed would be best. |
| All times are GMT -6. The time now is 06:31 AM. |
