VAF Forums
-   RV-14 (https://vansairforce.net/community/forumdisplay.php?f=109)
-   -   Advice-Vertical stabilizer (https://vansairforce.net/community/showthread.php?t=153122)
Eztroller 09-06-2017 03:56 PM
some of the rivets are folded over slightly..... all are within specs, but I don't like how all of them "look." Not expecting perfection, but also don't want to miss something.
bkervaski 09-06-2017 03:59 PM
Can you post some pics?
Eztroller 09-06-2017 04:00 PM
https://photos.app.goo.gl/BhT1l7RrLDXSBpG52
https://photos.app.goo.gl/UcVqQ29zxK1DmbQL2
https://photos.app.goo.gl/BEl8SHabzmV8jLKY2
bkervaski 09-06-2017 04:02 PM
Not perfect but look fine as long as they are in spec .. and nobody will see them .. as long as you can live with it ;) build on!
Eztroller 09-06-2017 04:02 PM
hopefully that is the correct way to view the pics....arghhh!:)
Eztroller 09-06-2017 04:04 PM
is am using a Numatx 3500 squeezer, about 80PSI, and went reaalllyy slow when squeezing. Is there another technique to make them more uniform?
bkervaski 09-06-2017 04:06 PM
I don't know anything about the Numatx but mine (Cleveland Tool) has a cam in it so the last bit of travel is kind of a "snap" which really gets the shop heads looking nice once you get the hang of it.
At least you put them in the right direction, I ended up drilling a good bit of mine out to reverse .. oops .. seems like a long time ago but was just April!
Eztroller 09-06-2017 04:20 PM
thx for the quick replies and info
climberrn 09-06-2017 04:32 PM
Not familiar with that squeezer, but mine gets the best results when they are squeezed at full speed, and always use the max PSI of 90. I have an inline flow restrictor that can be adjusted also if I need to come up on it slower.
Those don't look bad, but with a little trial and error I'm sure you'll figure it out.
Chris Cooper 09-07-2017 05:54 AM
You can use a C frame with the longer back riveting tool available from Cleaveland. They will all be consistent then. It was a tip from another builder and it works really nicely.
http://www.vansrv14.uk/index.php/201...liser-06-05-2/
http://www.cleavelandtool.com/Back-R.../#.WbEznNHTWhA
