VAF Forums
-   RV-12/RV-12iS (https://vansairforce.net/community/forumdisplay.php?f=73)
-   -   New Voltage Regulator Needed (https://vansairforce.net/community/showthread.php?t=152721)
rv7charlie 03-21-2018 08:37 PM
Ok; unsubscribing from this thread. Any further questions, PM or email me...
Phantom30 03-21-2018 08:52 PM
Originally Posted by tomkk (Post 1247668)
... because the last I knew they were a bit hard to come by here in the States. Has that changed?
Tom,
The link to order is: www.motoguzzisales.co.uk/index.htm
The F4112 is the fixed rate regulator, the F4118 is the stepped rate regulator
Also, recommended...is to install a 33,000 uf, 35 volt, 105 C capacitor. The RV-12 has a 22,000 one. Doesn’t hurt to add additional....I think SH has done more homework on this issue.
Piper J3 07-07-2019 06:35 AM
I hate to stir the pot again but I found what looks like a direct replacement for Ducati VR. For the guys that are going through these things like popcorn and want to stay with Ducati form factor this might be economical answer - $43.93 on eBay incl shipping. You?d have to compare part numbers and check specs but it looks like the real McCoy.
I installed a John Deere AM101406 at 100TT when my Ducati took a dump. No problems at all and now at 450TT.
backcountry 07-25-2019 10:40 AM
I got one of those $43.93 rectifier regulators. Visually it?s the same and the connector is the same. Plan to carry it along in case it?s needed to get home with. Don?t know the load it can carry.
ben barron 08-20-2019 02:54 PM
HAS ANYONE USED THE $43 EBAY REGULATOR?
Has anyone installed the $43.93 Ebay regulator to confirm it is the same and works? Lockwood?s replacement is $147.57.
NinerBikes 10-25-2019 03:38 PM
Originally Posted by Piper J3 (Post 1357667)
I hate to stir the pot again but I found what looks like a direct replacement for Ducati VR. For the guys that are going through these things like popcorn and want to stay with Ducati form factor this might be economical answer - $43.93 on eBay incl shipping. You’d have to compare part numbers and check specs but it looks like the real McCoy.
Just ordered the John Deere model. Is that plug and play compared to the original Ducati VR ? search " ebay Rectifier Voltage Regulator John Deere Mowers Tractors AM101406 MIA881279 Just noticed that the pins are rotated 90 degrees from vertical to horizontal.
