VAF Forums
-   Traditional Aircraft Engines (https://vansairforce.net/community/forumdisplay.php?f=21)
-   -   Aerosport vs Mattituck (https://vansairforce.net/community/showthread.php?t=1526)
tx_jayhawk 05-12-2005 11:55 AM
I have been engine shopping the big 3 (Aerosport, Mattituck, and Superior), and I am trying to compare the options on an "apples to apples" basis. Specifically, Mattituck advetises the O-360 for 17,990, while Aerosport advertises the same for 19,800. Other than the warranty difference (Aero is 2, Matt is 1), does anyone else explicitly know the difference? I've heard good things about both, and I am trying to understand the differences. I spoke with Bart real briefly, and I was not able to quantitatively understand the difference.
Also, does anyone have experience with the horizontal (cold-sump) with a carbureted engine? I don't seem to see that option around.
Thanks for the help. It seems the matronics list is pretty much a waste of time nowadays (it's like old lady gossip and 3 year old name calling).
Scott
Ironflight 05-12-2005 12:58 PM
Call Mahlon...
Scott -
I was exactly where you are at the beginning of the year - same three options. I called and talked to Bart, and was very impressed. Then I talked with a couple of folks at Superior, and got a funny feeling - different stories from different people at the same company, and kind of like they were trying to guess what I wanted to hear...then I called Mahlon Russell at Mattituck, and had another very favorable impression.
I came to the conclusion that I would be very happy with either an Aerosport or Mattituck engine - both of them are commited to a quality product, and they will build the engine with the parts you want. My choice then came down to convenience in visiting the faciltiy while they built my engine -something I wanted to do - and Mattituck was the easiest from Houston (just jump on SWA to Islip). The fact that they were cheaper was nice, but not a sole deciding factor.
I was extremely pelased with all my dealings with Mattituck, and the build-up trip. I can't say anything bad about Aerosport, and if I was closer to them, they might have ben my choice.
Paul Dye
gmcjetpilot 05-12-2005 01:36 PM
You can't go wrong
I think location location location. Where do you live? Check shipping cost and there may be tax of duty issues from Canada, which they can address. Call both of them and talk to them.
I have called both companies and liked what I heard, and from what others say I have heard almost 100% good things about both. You can't go wrong from a quality standpoint. I would lean towards Matt if you are on the East side of the Mississippi river.
The thing that impressed me about Mattituck, besides price, is they are real flexible. They will delete, add and mix-n-match options or ECI/Superior parts to best advantage. Superior parts are a little more expensive in general than ECI but not necessarily better. Mattituck recommends/prefers the ECI cylinders for example, because they have better resistance to corrosion. Nothing wrong with Superior, but they know personal planes fly so little that corrosion resistance is a good characteristic to have in the Jugs. Unless you are flying almost every day or other day corrosion is a factor, espically in some wet parts of the country.
This is where buying direct from Superior falls short, price and flexibility. If you buy a straight up engine, you are fine, but with extras or options they just add on to the price and give very little or no credit for the parts being substituted, like electronic ignition. Mattituck has a good site with credits and prices of a wide range of options.
You will pay a premium to by direct from Superior, but some people find their build-it-yourself class a real learning experience, and after all that is one of the main reasons for building a plane, learning. However it will cost more to do the class.
I would check around. If you are in California (Eagle Engines), Oklahoma (America's aircraft engines). Shop around, there are many good engine shops. I also want a facility that has an engine dyno. Any good engine shop can build up a kit engine from new parts for you and do a nice job. As far as doing-it-your-self, I checked the price difference and the amount you save is small, especially when you factor in warrantee and the benefit of an initial Dyno break-in, both of which you don?t get with a do-it-yourself build. I have a A&P/AI friend and ended up buying a used Lyc O-360A1A. The core was thankfully good and got it cheap a number of years ago. My buddy and I did the overhaul thru ECI. I have about $11,000 all up into it, new everything except cylinders which I overhauled with new valves, pistons and rings. However I would like to have her on a Dyno before flying, which we could not do. There is an aviation college about 100 miles away with a dyno, and I am thinking about bringing it there, if I can talk them into it.
Good luck, get your checkbook out, George
mahlon_r 05-12-2005 02:54 PM
Scott,
No Horizontal cold air forward facing carb setup available from any supplier. Only with fuel injection. If you want to use a horizontal carb the only options are out the back or out the bottom, with out making your own out the front sump.
I will withhold any observations I have about Mattituck due to the highly prejudicial opinion I might have working there! All kidding aside if there are any questions I can answer for you weather here in public forum or privately please feel free to ask.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at you own risk."
