Main gear axle thread size
I've managed to damage the threads of one of my main gear axles on my RV-10. I need to get a die to clean up the threads a bit. What die size do I need to use? What are the thread specifications?
I'm going to call Van's in the morning, but I thought I would post here in the hopes that somebody may know. Thanks, Bob |
May be able to repair it with a thread file, less expensive than a die.
https://www.mcmaster.com/#thread-repair-files/=19120fn |
RV3 has 1.250 diameter with 16 threads per inch...
The RV-10 is 1.5 inch, but I don't know the thread size. My tap,set was at home today. If I can't get the info from Vans tomorrow, I'll attempt to use some taps to determine the thread size and count.
Thanks Don! Bob |
Due to the eclipse, I couldn't get through to Van's support and nor did they return my email. I did get a thread gauge and measured it myself. It's 1.5" and 16 tpi.
| All times are GMT -6. The time now is 02:44 PM. |
