VAF Forums
-   RV Ongoing Maintenance Issues (https://vansairforce.net/community/forumdisplay.php?f=76)
-   -   New engine after 15 years, change mounts? (https://vansairforce.net/community/showthread.php?t=152435)
BMW_X6M 08-16-2017 12:46 AM
I have purchased a new Lycoming engine from Van's to replace the original rebuilt O-320-D2A in my RV-9A. The engine was installed close to 15 years ago by the original builder I would assume. Should I also plan on replacing the engine mounts? They look OK externally as far as I can tell.
Jpm757 08-16-2017 03:23 AM
Absolutely
Steve Melton 08-16-2017 03:46 AM
if you go with the Lord mounts, please report a comparison to the old if they were Van's.
turbo 08-16-2017 04:26 AM
hoses too. :)
humptybump 08-16-2017 05:51 AM
We're going through a similar update, albeit only 9 years. New mounts, hoses, exhaust gaskets, etc. - pretty much anywhere "new meets old".
Bill Boyd 08-16-2017 06:38 AM
So, my Lord mounts are 19 years old
and I'm not noticing any abnormal airframe vibrations (possibly due to a dynamically balanced prop and maybe the P-mags help at low rpm). No goo dripping out of any elastomers.
Should I replace on condition, or only if I have the engine off for another reason? Did my hoses about 8 years ago - all SS over teflon, from SacSkyRanch, so they're probably okay.
It's sad how much this plane sits now that I'm building again, and have a young family of 4 that prefers to travel together vs. Mom and Bill running away for the weekend. I think I'm at 8 hours year-to-date. :(
rightrudder 08-16-2017 10:22 PM
Just about any rubber part FWF will be toast in 10 years. Heat, vibration and ozone all take their toll. A new set of mounts is cheap insurance.
Bill Boyd 08-17-2017 09:43 AM
How will I know I have a vibration mount problem if I'm not feeling abnormal vibrations? Insurance against what occurrence?
Just want to learn, and be wise.
Caveman 08-17-2017 11:19 AM
Bill, the following document has useful info for inspecting our engine mounts:
http://lordfulfillment.com/pdf/44/PB...tsBrochure.pdf
Joe
BMW_X6M 08-17-2017 11:26 AM
From the Mother Ship
If they appear to be OK, i.e. rubber is not hard/cracked/delaminated, it?s most likely OK to use them. There are plenty of mounts out there that are 25+ years old and still in service.
Van's Aircraft, Inc.
14401 Keil Rd NE
Aurora, Oregon 97002
503.678.6545
