VAF Forums
-   -   Cleaning wheel bearings (https://vansairforce.net/community/showthread.php?t=152256)
dspender 08-10-2017 07:55 PM
What type of solvent or name of a product should I use to clean the wheel bearings and wheel axle? Is gasoline ok? I think there must be something more effective or safe. I have taken the main tires and wheels off to rotate the tires and there is brake dust on the bearings and axle that I want to remove.
rockwoodrv9 08-10-2017 08:34 PM
Gasoline would be my last choice. For bikes, I used brake cleaner. I just hate the smell of gas and the blowing up part too.
BillL 08-10-2017 08:42 PM
I use mineral spirits. It does not dissolve the grease as fast as gasoline, but is safer. Compressed air is good to blow off the old grease and dry the bearing but be careful spinning it, the cage can expand and/or explode. Just be sure to use fresh for the last cleaning.
Jrskygod 08-10-2017 09:29 PM
100LL. Works great, readily available, dries fast, it's the all purpose cleaner. Probably not a good idea to smoke while using it tho.
Kyle Boatright 08-10-2017 09:44 PM
Mineral spirits, a throwaway cake pan, and an old toothbrush.
gasman 08-10-2017 10:15 PM
Wipe with paper towels. Spray with brake clean. Rinse with mineral spirits. Inspect. Re-pack with Sta-lube boat trailer grease from Napa Auto parts..... touch it and you will understand.
alpinelakespilot2000 08-10-2017 10:29 PM
Brake cleaner.
Michael Burbidge 08-10-2017 10:41 PM
Nothing
I've read here that you shouldn't use a solvent. Simply pack with new grease until all the dirty grease is pushed out.
That's what I've done for three years now.
Michael
Steve Melton 08-10-2017 10:42 PM
I've never cleaned mine. I inspect the race. If it's good, I inspect the bearing looking for any shiny flakes. Then I use a bearing grease packing tool and inspect the old grease that is forced out. If all is good, back in they go.
update: I'm Mike's shadow from above.
Mel 08-11-2017 06:44 AM
Originally Posted by BillL (Post 1195127)
Compressed air is good to blow off the old grease and dry the bearing but be careful spinning it, the cage can expand and/or explode. .
NEVER spin a bearing with compressed air. If it is not packed with grease, you will put more wear on it in a few seconds than a lifetime of normal use.
As said before, just pack in new grease until the dirty grease is expelled.
tim2542 08-11-2017 06:55 AM
In my experience with tapered Timkens it's more likely the inner race that will fail first. The roller contact patch is smaller here, (convex/convex) and the speeds are higher (smaller dia.). This is the hardest one to clean and inspect also.
That said, it seems most of us are in there looking and repacking pretty often and things won't get too bad before you catch it on the rollers or outer race.
Tim Andres
BillL 08-11-2017 07:31 AM
Michael
You are probably right, if there is no dust to get pushed in, that is a good way to just replenish the grease. If they were sealed, the synthetic grease would probably last the life of the plane anyway, so it is not grease, just cleaner grease we need.
If contaminated with brake dust or other dust, full on cleaning is in order. No use in making a grinding slurry. :eek:
Plummit 08-11-2017 07:33 AM
Years ago when I was stationed at Ft. Polk, LA, I was rebuilding a VW engine using leaded gas as a solvent. My friend walked in the room smoking a cigarette, and I asked him to leave due to the fire danger. He laughed and bet me that I couldn't ignite gas with a cig. I lost that bet. A cig does not burn hot enough to ignite gasoline.
I have won several similar bets since then, but the down turn in smoking has seriously cut into my lunch money fund. ;)
-Marc
Mel 08-11-2017 07:49 AM
-Marc
BE CAREFUL!!!! While gasoline will not burn, even with an open flame, the fumes directly above the gasoline WILL!!!!
This is NOT something to play around with.
Low Pass 08-11-2017 07:52 AM
Bearings and working with flammable liquids
I like to think I'm a pretty conscientious person when it comes to fire and chemical exposure after worked in petrochem mfg for 15 years and working on cars and planes for the last 35 or so years with no injuries requiring more than a band aid and a few choice expletives. But last winter I was doing some cold weather maintenance - wheel bearing inspection and grease, brake inspections, etc.
After removing the wheel and bearings, I tossed all the greasy parts in a plastic bucket and sumped some 100ll out of the plane in with it. Began sloshing it around to clean the parts. I think I got up to go get a brush and almost stumbled over the propane heater I had running next to me. Not sure how that didn't flash. Guess the cold temps kept the fuel vapors to a minimum, along with a little divine protection. Ironically/stupidly, I have a working parts washer about 30 ft away.
Just thought I'd share. Be careful, and think.
Vern 08-11-2017 07:58 AM
Gasoline
In college I worked 40-60 hrs a week at the local FBO. One day I commented to the boss that the fueler had a cigarette dangling from his mouth as he fueled our newest C150. Boss said it would not ignite and bet a coke that he could put his cig out in the now-full fuel tank. I fell for the coke bet but stayed well back as boss poked his cig into the full tank.
But,even so, it's not for me!
Friend's garage and half a house burned up while he was changing out a car fuel pump.
My own hangar almost burned up when a resident RV was calibrating his fuel gages.
Static can be more of an ignition source than a lit cigarette ..
Ground wires, outside hangars only, proper containers, fire extinguishers handy, and great care when dealing with gasoline!
Gisnar 08-11-2017 08:28 AM
Back to bearing cleaning:
WD 40 works well.
Really like Hoppe #9, like the smell also.
DaleB 08-11-2017 08:36 AM
-Marc
Dad told me about his first engineering job after finishing college. He was getting the shop tour from the foreman. The foreman had a tin of gasoline sitting on the floor of the shop, and every time they walked past it he'd light a match and flick it into the tin of gasoline. Every time he did that, the match hit the gasoline and was immediately extinguished. That happened several times... until the last time, when there was a whoosh and an impressive fireball.
The shop foreman's point was, just because you might get away with doing something unsafe for a while, it's still not safe and eventually it will blow up on you.
I cleaned wheel bearings with gasoline swirled in the bottom of a can or jar for years. These days I wipe out as much as I can with paper towels, and use mineral spirits instead. I just don't like the gasoline stink, and I don't use avgas.
Plummit 08-11-2017 08:38 AM
I agree that's it's not something to play with - BUT - the way my friend proved it to me was he took a 1 gallon plastic bottle with gas in it, put the end over his lit cigarette, then proceeded to smoke the cig to the point that I could see the cherry glow through the plastic bottle! I stood on the other side of the room, but no fuel or vapor ignition occurred.....
In welding school after my Army stint I won a similar bet with a guy who tried to ignite gas in a cup and on a welding table with a cig. He even discharged 02 on the gas from an Oxy bottle! Something about the flash point of gas being above the temp of a burning cigarette.
So I asked my friend that originally taught me this why there are "no smoking" signs in gas stations? He smiled and reminded me that the object used to light a cigarette (lighter or match) would ignite gas. Duh! ;-)
~Marc
Christopher Murphy 08-11-2017 04:55 PM
No gasoline gas fumes fan out on the floor accident waiting to happenp
In a previous life I worked in the wheel and tire shop at Ohare airport for my airline ( a big one) and I spent weeks cleaning and inspecting wheel bearings and we always cleaned, inspected, repacked the bearings. I did this for the 747 dc 10s , dc 8s 767, 727 ,737..
Side note..
I have over 22,000 hrs and Im betting Im the only guy who has changed a tire on all of those planes and been a Capt on some of them too..😁
Cm
snopercod 08-11-2017 05:10 PM
Bearing packer?
May I ask a dumb question? What kind of bearing packer are people using? I see some of them have Zerk fittings and some don't. Which is better?
Larco 08-11-2017 05:21 PM
In my neck of the woods this is popular. I think if you shop this item it can had for less money else where, maybe.
https://www.napaonline.com/en/p/SER774005
Ironflight 08-11-2017 05:21 PM
I've tried several of them - and always end up using the palm of my hand fingers to work the grease in, just the way my Grandad taught me a long time ago. The gimmicky ones just don't seem to do the job I'd like. The only change is that I wear nitrile gloves these day, because it makes it easier to clean up my hands afterwards.
On solvents, I had always been taught to use Stoddard Solvent for aviation work, and have done that for years too - but nowadays, its hard to find by that name. I did some research, and it turns out that Stoddard is another name for Mineral Spirits, so that is what I have been using lately. Much less likely to go "boom" than gasoline or Avgas (which I have also used in a pinch, but prefer not to take the risk if I don't have to.
RV6_flyer 08-11-2017 05:39 PM
Sounds like the way I pack bearings. Dad taught me that way more years ago that I can remember.
Stoddard solvent is my preference if cleaning out all the way. Have been known to use mineral spirits, diesel fuel, and Jet A but NEVER gasoline or 100LL. Did not know mineral spirits and Stoddard solvent was the same thing. Around my airport, people talk about using Varsol. Sounds like we all use the same thing but has different names.
bret 08-11-2017 06:31 PM
The 104 flash point safety clean was my favorite in a solvent tank, then emissions regulations started taking over and then 140 flash point, did not clean as well, then the orange juice solvent, then the heated water base with soap and live bugs that eat grease, take the parts out and then they would rust. Then they took our solvent tank away! so now we use cans and cans of brake clean........what fumes? bet you can't guess what state this is.........getting rid of hazard material is expensive. By the time you buy many cans of cleaner, you could probably buy new bearings and pack them.......
David Paule 08-11-2017 06:34 PM
That's what the Air Force taught me a long time ago when they were trying to make me into a helicopter mechanic. Both of these.
That's what I use on my C-180. Works great.
Dave
Mel 08-11-2017 06:39 PM
Yep! That's the way I was taught by my Dad and that's the way I still do it.
koupster 08-11-2017 06:41 PM
Diesel
I've started using diesel for most parts cleaning. It's much cheaper than mineral spirits; just take an empty gallon oil jug to the service station. If left uncovered when you're not around for a bit, most of the smell goes away.
Cheers, David
RV-6A A&P
plehrke 08-11-2017 06:43 PM
Stoddard solvent or mineral spirits depending what I have and then rinse with brake cleaner. Always thought having the solvent residue left on the bearing could break down the new grease. Brake clean leaves very little residue.
A lot easier to inspect bearing for pitting if you clean them before packing with fresh grease.
dspender 08-12-2017 09:22 AM
Sounds like mineral spirits and brake cleaner is the ticket. I have so much brake dust from dragging brakes I don't want to just push more grease in. Now working on what is dragging the brakes.
JonJay 08-12-2017 01:59 PM
Make sure your master cylinders are retuning to the top. If not, correct the bolt alignment. Search for posts on brake drag for other suggestions. Don't succumb to adding springs until you fix the bolt alignment if indeed
they are not returning.
BillL 08-12-2017 02:26 PM
I did the long bolt mod on my 7, but after reinstalling and bleeding the brakes, see that the spring stiffness of the hoses could be the culprit that keep the gentle spring force of the master cylinder from returning fully. The OP might look at that, but the long bolt is a must, IMO.
