Misinformation!
Not trying to start something, but a friend of mine just sent this to me:
http://www.121five.com/admin/Feature...aintenance.pdf This contradicts a lot of what I "thought" I knew about experimental and what I can and can not do. I'd like some feedback on the article please. Thanks, -Dan |
Unfortunately much of this article is "Hogwash".
ANYONE can perform maintenance and or modifications on an Experimental Amateur-Built aircraft. Remember, Part 43 only applies to the condition inspection because it is referenced in the Operating Limitations. The reference of the 120 hour repairman course for Light-Sport is applicable to SLSA, not ELSA. For ELSA the Repairman Certification (Inspection) is a 16 hour course and only applies for the condition inspection. Since an ELSA is Experimental, no repairman certificate is required for maintenance. |
https://www.eaa.org/en/eaa/aviation-...er-maintenance Tim Edit: See Mel's more complete answer. |
I would also go as far as to say that even if you didn't build it, if a Repairman's Certificate has not been issued for that specific aircraft, you could still apply for the certificate provided you had the requisite experience and knowledge and could demonstrate that to the FAA (eg you've built other E-AB's but decided to buy this one). IOW it's not tied to the build itself -- that's just the usual way us non-A&P types get the required experience and knowledge.
EDIT: the above is incorrect -- it is tied to the build. |
-Dan |
Looks like you have an RV-10, so you are good-to-go. Just remember, what is legal is not necessarily prudent! |
Write the guy & tell him the error of his ways. I just did, with a link to EAA's experimental maintenance page.
Charlie |
| All times are GMT -6. The time now is 02:12 PM. |
