VAF Forums
-   -   Lycoming SB 632 7/17/2017 (https://vansairforce.net/community/showthread.php?t=151506)
Dustyone 08-09-2017 06:21 AM
AWB 85-020 Issue 2 ? 9 August 2017
Meanwhile ,down in Australia....
https://www.casa.gov.au/file/187126/...token=itziGCHn
RV6_flyer 08-09-2017 07:14 AM
Not sure I understand why Australian Civil Aviation Safety Authority listed Group 1 Factory Engines during 2011 calendar year. From reading the Lycoming SB, the bad parts started late 2015.
Copy / Paste Lycoming SB632B: "If your engine was overhauled or repaired on or after November 18, 2015,"
airguy 08-09-2017 07:31 AM
As several have speculated, it appears this problem may be a bit more widespread than the Lycoming SB indicates.
rgbewley 08-09-2017 08:09 AM
Originally Posted by BillL (Post 1189093)
Rhonda, so what is (your opinion) the design issue? Are the Lyc bushings just dimensionally poor or is the bushing material too soft and they are yielding and losing preload?
Sorry for all the questions, but one more - are the bushings installed with rod and bushing cold and pressed, hot, or light pressed then internally burnished to expand and reamed to final dimension?
Sorry for the delay in response - still getting back in the swing after Oshkosh. I'm not privy to information as to whether it is a manufacturing issue or a material/design issue.
My initial thoughts were that the OD of the bushings was simply out of spec and it got missed in QA, or maybe that they weren't properly installed in the factory engines, but that doesn't make sense as Lycoming also quarantined lots of bushings sent out for field overhaul of rods.
The bushings are installed at room temp, pressed in then burnished and machined or rolled to final dimensions. I believe that ASSI rolls theirs to final dims.
rgbewley 08-09-2017 08:13 AM
Originally Posted by RickSolana (Post 1193602)
Well, my brand new engine is on the list. 80 hours, flying since March. After reading Mike Busch's comments, I am thinking I should take this plane to a really good repair facility and not just a local A&P.
Can anyone recommend a good repair shop to me? I am in Virginia, but am willing to fly it to a shop that is further away. In the end, i want to be flying an engine that I trust has been reassembled well. Some names I have come up with so far are Penn Yan, Zephyr, Triad, Aero Performance in PA. Does Aviall do repairs or just parts? Does Lycoming do engine repairs at their shop? What about Barrett's, Aerosport power, Superior, etc. You can tell I don't know anything about these shops!
Thanks for the help,
Rick Solana
RV-10
N804RS
Hi Rick:
We can complete the work for you and apply for the warranty through our Lycoming distributor if you like. I don't know if Lycoming will pay freight to and from me though. Worth checking on. Please feel free to contact me directly if you need assistance. 918-835-1089
jwilbur 08-10-2017 12:22 PM
FAA released AD
FAA releasing AD for "all" listed engines.
https://s3.amazonaws.com/public-insp...2017-16968.pdf
DanH 08-10-2017 01:01 PM
See the CASA link previously posted #61. Interesting reading, entirely correct or not.
BTW, for those who don't bother checking the suction screen at every oil change, Section 5 is worth a look.
BillL 08-10-2017 06:16 PM
Rhonda, Thanks for a precise reply. That helps, If the busing was pressed and machined, I could see how the large gap might might have yielded less than 100% contact, but if it is roller burnished the expansion in place would press it to the rod wall. The CASA report shows an failure that I am not familiar with, it appears that small pieces are fatigued and broken off, resulting in a cocking load on the con-rod. Thinner walls are more difficult to retain installation press fits.
Dave Bernard 08-12-2017 10:40 PM
I bought an experimental O-360 through Vans about a year ago and it's on the list... about 50 hours on my engine now with no problems.
The odd thing is, I only found out about this from an A&P friend during casual conversation. Lycoming knows I have an engine on the list, shouldn't I have heard of this through them, like a serious-looking envelope in the mail or something?
What is the normal channel for an engine owner to be notified of a time sensitive SB?
Tim Lewis 08-14-2017 06:35 AM
In prior years, the owner who wanted to stay informed could buy a set of service letters/service instructions/service bulletins (SL/SI/SB) from Lycoming, and subscribe to annual Lycoming updates for a fee (about $50/year). Envelopes from Lycoming would show up in the mail every month or so with the latest documents. Starting this year, Lycoming stopped that service. You can now go to http://www.lycoming.com/contact/know...e/publications and see the latest publications, and sign up for notification of when publications are released/updated.
If you want a full set of publications (including hundreds of documents not shown on Lycoming's web site), Lycoming points you to a couple of vendors who sell electronic subscriptions for several hundred dollars per year.
