Buzz box question
I have pmag and a Slick. Do I need the deluxe single mag timing light or can I use half of the more universal dual mag synchronizer to time my Slick?
Also if anyone knows part no. for o-ring under oil cap I appreciate the info. |
Jim,
You can use a single or a double. The double just gives two leads and gives different tones and lights for each side. either one will work for a single mag. You can also borrow mine if you want to fly up to 06C or wait until I next ask you to be a safety pilot for me :-) Too bad I didn't know earlier. I flew right over you on my way back from Dayton on Tuesday. For the o-ring, I just picked one out my HBF assortment box. You can measure it and go to ACE to get a good size. Pick about 1/16"-1/8" smaller in ID than the OD of the male threads on the dipstck. Larry |
Thanks Larry.
Maybe cya at taildragger tues. (but everyone's welcome).
| All times are GMT -6. The time now is 05:47 PM. |
