Engine Timing For Mags
How are you guys timing your engine mags.?? I had an order in at Aircraft Spruce for the Rite System, but I have learned they are out of business. Thanks, Mark C. RV9A
I built one of these http://www.brewingtontech.com
Works fine and mag timing is fairly simple if you take your time and triple check everything. Have somebody who has done it help you the first time. Chris |
Mag timing
thanks guys.. I'm tired of building things, the Aircraft Spruce looks like a good choice. Mark C.
Ditto for this unit.
Yours, R.E.A. III #80888 |
That will work just fine, we have one in our shop and it works great.
| All times are GMT -6. The time now is 11:35 AM. |
