Dynamic prop balance
Hi All,
I'm looking for a shop in the southeast Wisconsin/northern Illinois area that can do quality dynamic prop balancing, preferably with Rotax experience. Any/all suggestions appreciated. Barry |
http://www.aviationvibes.com/vibrati...nd-mitigation/ |
I'm curious... why do you feel the need to balance your prop? I set the pitch on my blades with Van's sheetmetal gage and I'm very pleased with the flight performance and engine/prop smoothness especially at cruise RPM.
I have balanced quite a few 12's and every one benefited significantly. It is also a recommended procedure by both Rotax and Sensenich.
Just finished balancing mine this weekend. Started out at 0.21 ips, was very happy with the final result after adding 11 grams of weight.
![]() John Salak RV-12 N896HS |
Prop balance
Where and how did you attach the weight?
Call Poplar Grove Airport, IL they have a guy that balances props. About $250. Mark C.
The factory listed weight difference between the two Sensenich blades is 6 grams (1204g and 1198g), so the weight location is actually near the root of the lighter blade. Not sure how that compares with other RV-12s, but it may be an indicator of the improvement you can expect from dynamic balancing. John Salak RV-12 N896HS |
I spent Saturday morning trying to balance my RV6 / Superior IO360 / Sensinich setup with the same Dynavibe model shown in the photo above. However after 8 runs trying to dial in on the best balance, I discovered that none of the results were repeatable on subsequent runs! I removed all weights and headed home to ponder what could be going on.
Has anyone else found repeatability to be a problem? I was able to get down to about 0.12ips, but a 2nd trial with no change yielded 0.38ips! Originally my setup was showing 0.42ips. The last run of the day was back to no weights, and I was getting 0.57ips. Not sure what is going on. We had similar results on a different engine and airframe earlier that week. Don |
| All times are GMT -6. The time now is 06:12 AM. |
