VAF Forums
-   Traditional Aircraft Engines (https://vansairforce.net/community/forumdisplay.php?f=21)
-   -   What happens if you don't change your engine oil? (https://vansairforce.net/community/showthread.php?t=149804)
airguy 05-26-2017 07:09 AM
Originally Posted by turbo (Post 1175671)
sounds like the 6 qt mark is actually the 7 qt mark now. :eek:
Remember that you're filling the new oil filter too.
alpinelakespilot2000 05-26-2017 12:04 PM
Originally Posted by BCP Boys (Post 1175642)
You also have to consider how long does it take you to fly 25 or 50 hours. I've easily flow 25 hours in a couple of weeks at times and at other times in the past when I flew a gas guzzler and fuel was $7 to $8 per gallon, I flew 25 hours in a year.... Obviously the time span has to be considered.
I follow Mike Busch's recommendation: 50 hours (with filter) or 4 months, whichever comes first.
YellowJacket RV9 05-26-2017 12:15 PM
Yep, I fill the oil filter as much as possible when installing it, so that accounts for probably .5qt - I may end up a tad over the 6qt line on the dipstick, but after that it generally stays right at that line for 20-25 hours before I need to add anything.
In any case, not too worried about dipstick accuracy because I know how much goes is and how much comes out (not much).
Chris
