VAF Forums
-   RV Ongoing Maintenance Issues (https://vansairforce.net/community/forumdisplay.php?f=76)
-   -   Oil from Fuel Pump dump/vent (https://vansairforce.net/community/showthread.php?t=14974)
AlexPeterson 02-05-2007 09:50 AM
I have the dump or vent for the fuel pump just poking through the belly skin just in front of the firewall. I noticed a little bit of oil splattered in this area after the last flight, and I'm assuming something is amiss with the fuel pump. I thought I would ask if there is another explanation. I see perhaps one drop spread out on the belly, but I've never seen this before in 830 hours. It is the high pressure version. I will not fly until it is resolved.
Thanks in advance.
mahlon_r 02-05-2007 10:23 AM
Time for a new or overhauled pump.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
AlexPeterson 02-05-2007 10:43 AM
Yes, I was quite sure of this, but thought it wouldn't hurt to check.
