VAF Forums
-   ADS-B (https://vansairforce.net/community/forumdisplay.php?f=113)
-   -   ADS-B Compliant for $1,000? (https://vansairforce.net/community/showthread.php?t=149168)
terrykohler 05-02-2017 04:30 AM
http://www.uavionix.com/products/echo-uat/
Claims to interface with AFS, Dynon, GRT, and MGL. Does anyone have experience with these units? Certainly looks interesting.
Terry, CFI
RV9A N323TP
Kyle Boatright 05-02-2017 04:51 AM
Here's a recent thread:
http://www.vansairforce.com/communit...light=uavionix
BrianDC 05-02-2017 05:57 AM
Looks promising, hopefully more players will be releasing ADSB-out solutions.
I was impressed at what Levil was showing off at SunNFun with their Beacon.
They are working on getting it certified/approved, but will should meet the ADSB mandate and only requires power and GPS antenna hookup so installation should be pretty easy.
I thought I heard it was going to be between $1000 and $1500 or so. If they are successful I'm sure others will be replicating this idea.
GalinHdz 05-02-2017 06:15 AM
Terry, CFI
RV9A N323TP
It still requires an external ADS-B compliant GPS position source, which can easily be the most expensive piece of equipment.
:cool:
pitts flyer 05-02-2017 08:24 AM
:cool:
Not true anymore. There is the Garmin GPS 20A (though you need the antenna which can be bought on Ebay for $100-200). Uavioni has the SkyFyX All IN One Antenna (or separate receiver and antenna) no prices yet, but I would expect it may be well below $1k. Dynon has the 2020 GPS Receiver/Antenna for around $500. And GRT has the Safe-Fly 2020 ADS-B Compliant GPS Module also for around $500 (which is the Uavioni system I believe).
DaleB 05-02-2017 08:36 AM
SkyFyx is $499, or $399 if you buy it bundled with the EchoUAT. I was just looking at that this morning. The Garmin only seems to make sense if you have a G3X, it's pretty spendy.
I'd buy the UAvionix, but I want to wait and see what the Levil Blade sells for when they start selling it.
Sam Buchanan 05-02-2017 09:04 AM
I just purchased a Stratus ESG transponder that includes a compliant GPS....will be ~$1650 after the FAA rebate.
GalinHdz 05-02-2017 09:24 AM
And those are ADS-B compliant GPS sources when connected to the individual EFIS so keep adding those costs. FWIW, I was most impressed with the iLevil "all in one" unit at SunNFun.
:cool:
Steve Melton 05-02-2017 09:56 AM
what impressed me was the low weight, 95 grams. did I read that correctly?
Steve 05-02-2017 10:10 AM
I'm also holding out for the Levil Beacon with an estimated price of $1300.
