As far as I know
there are no parts to adapt from the style harness you have to the style plug you have installed. Most likely you will have to replace the plugs you bought with the appropriate plugs. As you discovered, the letters preceding the numbers really do matter.
It gets worse. The nut has the wrong size threads, too, for that plug. REM and RHM cannot be interchanged, unless you re-do the harness.
I'd be interested in your new 37BY plugs if you can't use them.
Kelly PM sent. |
I guess the great deal that I got from my friend on the plugs wasn't such a good deal after all!
I already put my old plugs back in and stay tuned for my classified ad for these plugs. |
| All times are GMT -6. The time now is 03:11 PM. |
