GA 56 Forward of Windscreen
I'm planning some coax runs for GPS, Com's etc and I would like to know if a GA 56 antenna would fit between the windscreen fairing in the center and the aft side of the forward baggage door? I'm running the GA 56 to start with until I can afford the 20 A. Is there a minimum coax legnth between the G3X screen and the G 56 Antenna itself?
Many thanks Gibbo |
Yes.
We put our GPS antenna on top of the skin, just about in the middle of the baggage door hinge and maybe an inch or two to the left of the hinge line. This place work very well and your eye does not see it in flight. With the G3X touch we have installed it is a sort run from the back of the GDU-460 out to the antenna. I do not remember the recommendation of how long a coax run should be limited to, but I have seen them up to maybe 10 foot and working quite well. Most of the OEM GPS makers will give you a recommended length in their install manuals.
Hope this helps, Yours, R.E.A. III #80888 |
Cheers Gibbo |
Sorry.
No worries Rob thanks for your help I will wait until I have the canopy cut and fairing installed before I can work out exactly where I want it, I'm just making sure it will work in that position so I haven't got to allow for extra coax elsewhere.
Cheers Gibbo |
Right track
Keep stirring that red dust and you will get there. Yours, R.E.A. III #80888 |
| All times are GMT -6. The time now is 02:28 PM. |
