Garmin GSU25
Hi All,
From the G3X installation manual; "Although mounting the GSU 25 to the threaded holes on the back of the GDU 4XX display is not generally recommended due to instrument panel flexing ..." I would like to know if anybody has mounted the GSU 25 to the GDU 460 on a standard RV8 instument panel and has experienced "panel flexing"? Or the rigidity of a standard panel for that matter. If it is susceptible to any flexing in the finished configuration. I was curious if the RV8 panel is less prone to flexing because of the narrower fuselage. Thanks in advance, Roger. |
Nope
We Have one on the back of the GDU-460 and it does very well. Good place to put it. We do have a lower edge panel shelf that makes the panel a lot stiffer.
Yours, R.E.A. III #80888 |
I'm not sure what stage your up to Roger but I mounted mine here
![]() Very rigid and an easy install with some 3/4 angle. Regards Nathan |
There was a similar thread on this in the RV-14 section.
Here is another reason you may not want to mount the GSU 25 to the back of the display and have pitot/static/AOA lines attached. http://www.vansairforce.com/communit...65&postcount=8 Thanks, Steve |
Thank you for the advice.
I see Steve's point about the pitot connection and I like Nathan's location so that sorts it for me. It will not go on the GDU. |
I tell a lie Roger! I've been away over the Easter period and had no access to check but the angle is actually 1"x 1.25". Here's another photo behind my panel so far.:D
![]() Regards Nathan |
| All times are GMT -6. The time now is 02:29 PM. |
