VAF Forums
-   -   Garmin 335/345 GPS out... (https://vansairforce.net/community/showthread.php?t=148556)
Michael Burbidge 04-12-2017 11:53 AM
If you buy the Garmin 335/345 (ADS-B) with GPS, does it have a GPS out channel that could drive the Dynon Autopilot, or some other autopilot for that matter?
Michael-
boom3 04-12-2017 12:15 PM
The built in WAAS GPS is just a position source. (It knows where it is but not where it is going.) You would need a GPS navigator to drive an autopilot.
Another question might be, does it have a GPS out channel that could provide a position source to a 406Mhz ELT?
Raymo 04-12-2017 01:28 PM
You could use something like the Aera 660 to drive your non-Dynon auto-pilot (e.g. TruTrak) and link the 345 via serial or Blue Tooth to the 660 for wx and traffic.
If you have a Dynon system, you would want the Dynon AP servos, transponder and GPS 2020 antenna plus the new ADSB-472 for an IN source of wx and traffic.
Lots of Q&A on the ACS site, where the ELT question has already been posed.
Q: My ELT (an Artex ELT 345) needs GPS position information via RS-232. Can the WAAS-equipped GTX-345 supply that information via one if its serial ports?
A: Garmin recommends connecting your ELT with a GPS such as the Aera 660 or GTN 650.
Alien 05-07-2018 12:08 PM
Was looking into how to intergrate the Artex ELT 345 with the Garmin G3X.
Below is what I found in the Garmin Manual. (Use either a GDU or GTN/GNS).
Artex has the wiring diagram for the ELT 345 Cockpit switch via the RS-232 connector.
2.1.1.21 Emergency Locator Transmitter (ELT)
The G3X system can provide NMEA 0183 formatted GPS position data to an ELT, via an RS-232 output from a GDU display. In an installation with a GTN/GNS navigator, an RS-232 output from the IFR GPS using the ?Aviation? data format may be preferred. For further ELT interface guidance, consult the ELT manufacturer.
