VAF Forums
-   RV-14 (https://vansairforce.net/community/forumdisplay.php?f=109)
-   -   Magnetometer & common fuse wiring harness (https://vansairforce.net/community/showthread.php?t=148264)
n982sx 04-02-2017 10:48 PM
Originally Posted by JDA_BTR (Post 1162769)
Beware there is a max CAN bus length limitation.... when you start putting CAN bus items a long way from the panel components data error rates may climb.
Well, there are two length to consider with CAN, bus length and stub length. Since all the runs will be bus length, I'm pretty sure you can keep the bus length under 40 meters in a 14, and that's for the highest bit rate.
Typical G3x stub lengths are on the order of an inch or two, well under the .3 meter length. The stub connection to the bus is made right in the connector.
However, please note that it may not be a CAN device. I have just inferred it from the promotional material and a Webinar Garmin gave on the new devices. It might still be a serial device. I hope not.
JHartline 04-03-2017 06:15 AM
GMU 11 info
More stuff here:
http://www.vansairforce.com/communit...ferrerid=16904
See post #12. Per Garmin the GMU 11 goes on the CAN bus and is not a serial device.
n982sx 04-03-2017 10:24 AM
Thanks, I was sure I read or heard it was but when posting my answer I couldn't find it in any press release.
