Vegas Prop Balance
Ever since I had the Sensenich Wood on my RV-4 (O-360) refinished and re-installed, I've noticed a slight pulsation/oscillation in the 1100-1800 RPM range. 1400 RPM is the worst, when you're in the descent in the pattern.
Like Sensenich says, I checked the torque after the first flight. After a bit of tightening the pulsation improved but didn't dissappear. I'm guessing it needs a good balancing. Is there anyone in Vegas or nearby who can do it? Thanks, -Martin 402BD |
vegas prop balance
Martin,
I have a wood prop on my -6 also and I had this very same problem when coming into the pattern. After years of Experimenting I have found the solution. 1. Reindex your prop so it is horizontal when #1 is on TDC 2. Check the track @ the tip. Should be within 1/16" adjust with paper shims 3. Have someone dynamic balance below .1 IPS inches per second I bought my own prop balancer and tried every combination to figure this out. I hope that this helps you. I am sure that you will not believe the results. Good luck Jon RV-6 Flying 200hrs RV-10 building |
Martin, call John Bacon over at Boulder City. Sorry, I don't have his phone number anymore. Might get it from Dula @ 702-493-3361
Boulder City
-Martin 402BD |
| All times are GMT -6. The time now is 06:34 PM. |
