Leaning
I am in Michigan with OAT10-45 F. MP 22.5 and Prop 23. 3-5000 ft. I lean till just lean of peak at gph is about 11.0. Is this what others are seeing?
I should add, CHTs are about 340 with those settings.
Though you are looking for a GPH answer, you might also read up on proper mixture operations by John Deakin.
http://www.avweb.com/news/pelican/182084-1.html Lots of other interesting and educational articles, as well. http://www.avweb.com/news/pelican/182146-1.html |
Good info...
I can second the John Deakin articles, they were immensely valuable!
Dovetailing with those is a series of EAA webinars put on by Mike Busch on the subject. Leaning Basics: https://www.youtube.com/watch?v=_Vfi...GA0Ld&index=42 Leaning: The Advanced Course https://www.youtube.com/watch?v=X-tK...GA0Ld&index=39 Flying efficiently in a world of $7 Avgas (a little older, obviously): https://www.youtube.com/watch?v=ZBr6...GA0Ld&index=36 |
bob |
As a business partner with John Deakin, George Braly (GAMI/TAT) and Walter Atkinson, I can also endorse those comments above.
I strongly suggest you sign up for their engine management course (nothing in it for me ;) ) and you will learn how to understand what to do not just be too a single case recipe which only works at one instance. www.advancedpilot.com You should fly Wide Open Throttle all the time except when you want to slow down. You would not fly with a dirty air filter so why close the butterfly doing the same thing? Next RPM is best between 2300-2450 and depending on your engine and prop the 2400 range works well, but pick a smooth "happy place". Then fly it outside the red box as per the cheat sheet in the article link below. read this carefully and print off the red box / outside the box bit. http://www.avweb.com/news/pelican/182583-1.html Red box simulator https://www.advancedpilot.com/redbox.html Target EGT climbs (again read Deakins articles thoroughly). https://www.advancedpilot.com/tech.html Hope that helps! |
I spoke with Mike Busch yesterday and my take away is as you said; fly with wide open throttle, prop 22-24 and lean of peak. Assure CHTs remain below 400 for my Lycoming. My GPH at those settings will determine % power, ie for my 540 multiply GPH X 14.9 and divide that by 260= % power.
All good stuff if you have CS prop.
Many do not. My take on that situation is MP to 23 or less and you can lean all day to hearts content, will never damage engine and plugs stay clean. WOT all day applies only with CS prop. Did it all the time with Subby and MT prop worked great even at 2500'. WOT and 1900 rpm provided great efficiency. Of course engine had knock sensor which Lycoming does not because it vibrates too much. And even if knock were sensed, it does not have brain to adjust timing. |
Try it out and you will see. ;) |
Why does a CS prop make a difference?
I thought I understood LOP operations but I'm obviously missing something.
Why does a fixed vs CS prop make any difference? |
Thanks!
Thanks Todd - an engine management course sounds like what I need. Clearly over my head here.
http://www.avweb.com/news/pelican/Pe...-182085-1.html Once there you can see the links to other articles on engine management covering all phases of flight from startup to shutdown. |
| All times are GMT -6. The time now is 01:46 AM. |
