Of all the things to argue about on this forum, this has to be one of the more pedantic.
Two relevant/amusing experiences from my past. When I was in the AF stationed in England, my Jaguar had a bad front seal leak. Being a poor airman at the time, I did not have the resources to keep throwing ATF into it every day nor the motivation to spend the weekend dropping the tranny and replacing the seal. What I did have though, was access to an unlimited supply of 5606. So that's what I filled it with. Every day for months. I'll bet I ran 50 gallons of the stuff through that tranny before I finally installed a new seal. Was still running fine on 5606 when I transferred back home a year later. When I picked up my Tri Pacer and serviced the brakes, I found that the previous owner had serviced it completely with DOT 3 (automotive) brake fluid. The Certified Cleveland brakes didn't seem to mind one bit. (Yes, I went with 5606) I have a lifetime of 5606 around, but I'd have no trouble at all adding ATF out on the road if required. Power steering systems use it as do convertible top systems. Is it just a slow week on the forum? |
Neither Van's nor any brake manufacturer I'm aware of has tested or approves using ATF in their brake systems, but I guess you're just smarter than they are. Until they do, thank you very much but I'll stick with the "approved" fluids. |
Brake Fluid.
For what its worth: It was years ago, but I once spent days replacing parts and rebuilding the brake system on a Cherokee 6 that had been operated for a couple months with automotive (Dot 3) brake fluid. Many of the ?O? rings were very soft and gummy. On my 9 I will use the higher flash point Aviation Grade Fluid or ATF. Only 5606 in the Pacer. Don Broussard RV9 Rebuild in Progress 57 Pacer |
Flash point of Royco 782 (MIL-PRF-83282) and Mobil 1 ATF appear to be about the same 445F/220C. http://www.qclubricants.com/royco/royco_782.htm So unless you're just "very frugal" (I'm being nice here), or just want to be different, there's really no good reason not to use what the brake manufacturers recommend. |
It's like the rest of aviation, there are standards we follow in the industry that are considered accepted practices, like manufacturers manuals and AC 43-13, you don't have to do it that way but those are considered "approved" methods of aircraft maintenance and repair. Can you do it any way you want because it's experimental, sure... but please don't imply I am being "morally superior" because I choose to use accepted aviation materials and practices and not the methods "approved" by some folks on VAF. Ok I'm done. |
Again:
the technician's manual for Parker (Cleveland) brakes says: Hydraulic Applications - Use fluids compatible with the system MIL-H-5606 / MIL-H-83282 (Red Oils) Skydrol ? Only compatible with itself So...is ATF compatible with aluminum? I'd guess so. Is it compatible with the o-rings? Depends on the o-rings, I guess, but evidence is that it is compatible with the ones we're using. What else is in the brake system for it to be incompatible with? |
Did a bit of Googling trying to find out the chemical differences between 5606 and ATF and didn't find much. I did find that people are using it interchangeably in automotive lifts, sailboat autopilot systems, industrial hydraulics and other stuff - some of it with claimed manufacturer endorsement of interchangeability. So I guess if we want to ignore the empirical evidence offered by those who are using ATF in their brakes, a simple test would be in order. Cut a "certified" O ring in half and drop a chunk in a jar of 5606, the other in ATF and let it sit for a while. Once the soak period is over, compare each half and see if there is any sign of distress from the ATF half. Swelling, durometer, and general appearance, should be readily apparent. |
ATF
I don't know what all the fuss is about on using ATF in aircraft brakes. The O rings are compatible with petroleum based oils. ATF is such; any hydraulic oil will work.
I have been using ATF for over 40 years. An engineer friend used ATF in his 310 Cessna for 35 years. I probably have close to 4,000 hours (different airplanes) using ATF in my brakes. Never had a problem! Thank goodness for experimental aircraft. |
| All times are GMT -6. The time now is 06:16 AM. |
