VAF Forums
-   Fuel Injection Systems (https://vansairforce.net/community/forumdisplay.php?f=94)
-   -   Dukes pump died (https://vansairforce.net/community/showthread.php?t=147849)
kaweeka 03-20-2017 06:21 PM
Dukes pump died
My Dukes high pressure electric fuel pump died this weekend. It's the 4140-00-19A. Rated at 35GPH at 21 PSI. I was shocked to see a $1395 price WITH exchange. I had no idea. If anyone has one that is taking up space on their shelf, I would be interested. Also, I saw a Weldon 8163-A high pressure pump for experimental's for $300 on ACS. If anyone has insight as to the difference please tell me. That's a BIG difference in price for what seems like a similar product. There has to be a reason aside from the non-PMA....right?
Dave
Mike S 03-20-2017 06:25 PM
I saw a Weldon 8170-A high pressure pump for experimental's for $300 on ACS.
$1095 of course:D:D
Sorry, just could not resist..........
kaweeka 03-20-2017 06:26 PM
Well played
RV Jerry 03-20-2017 07:20 PM
I have used the Weldon pumps on several airplanes although the part # is 8000A and the price was around $800 they work fine
Andrew Anunson 03-20-2017 09:27 PM
Dave
$300 is the core value of the low pressure 8170-A. The core value on the 8163-A is $400. If you send your core, a rebuilt one will cost you $1185 on the ACS website. Weldon makes an excellent pump...
Thanks!
Andrew
kaweeka 03-21-2017 09:41 AM
Right now, I'm thinking of changing from the Firewall mounted pump and gascolator to the kit from Vans with the AFP setup in front of the fuel selector valve. I have their injection system anyway. Has anyone done this before in a -9A?
Chkaharyer99 03-21-2017 11:05 AM
David,
I think getting your auxiliary fuel pump off the warm side of the firewall is a good idea.
The Airflow Performance pump is about $390.00 and the filter is super easy to maintain. I have this set up on my RV-8, IO-360, without a gasolator. Works great.
Charlie
Noah 03-21-2017 11:24 AM
Sent you an email. I have a Dukes 4140-00-11 for sale.
kaweeka 03-21-2017 11:33 AM
Originally Posted by Chkaharyer99 (Post 1159612)
David,
Charlie
Yes, I need another project anyway. It's been a whole week!
Fastasp 03-23-2017 10:02 PM
David,
Charlie
Charlie! Do you have any suggestions about an RV8 with an IO360 without gasolator that has low fuel pressure problems AFTER a flight? Fuel pressure falls to about 13 to 15 psi on taxi in! Have removed the gasolator and connected the mechanical pump directly to the flow meter.
THX!!
Hayes
