VAF Forums
-   RV-9/9A (https://vansairforce.net/community/forumdisplay.php?f=5)
-   -   Looking for direction on cutting... (https://vansairforce.net/community/showthread.php?t=147010)
Roy25101 02-24-2017 06:53 AM
Could I get some advice on how to go about cutting the excess metal off the R-710 Rudder Brace Horn. It won't go through a band saw, it's too thick to snip. Any advice would be appreciated.
Mel 02-24-2017 06:59 AM
Typically on situations like this, I use a cut-off wheel in a Dremel or die grinder. Wear eye protection and be careful.
sbal0906 02-24-2017 07:04 AM
As Mel suggests, I used a Dremel with cut-off wheel but not right up to the line. Then, I finished it with the bench grinder.
Mel 02-24-2017 07:17 AM
Another caution; try using a belt sander instead of bench grinder. Grinding wheels and aluminum don't play well together.
edsong 02-24-2017 08:21 AM
A bench grinder is fine if you use a (3M SCOTCH-BRITE DEBURRING WHEEL) or something similar.
Eddy
wirejock 02-24-2017 08:27 AM
Dremel
+1 on the dremel. Cut it with plenty of extra.
I so have a big electric right angle grinder for cutting get thick stuff.
The Harbor Freight tools work fine.
mturnerb 02-24-2017 08:45 AM
Piling on to the dremel bandwagon. I use these wheels:
https://www.amazon.com/Dremel-EZ406-...s=dremel+metal
The ones that come in the dremel kit ("409 cutoff wheels") break easily but these seem quite durable - I've had good luck with them on fiberglass also. SAFETY GLASSES / GOGGLES ARE AN ABSOLUTE MUST when using these wheels.
az_gila 02-24-2017 11:39 AM
Ditto, but the House of Balsa 2 inch wheels are easier to use since the body of the Dremel gets less in the way...:)
Web search for "House of Balsa Tuf-Grind 2"
sbal0906 02-24-2017 02:16 PM
Eddy
Yes, thank you. I forgot to mention that I used the 3M scotch-brite wheel. I've started taking it for granted that that's what we all use. :o
Roy25101 03-01-2017 06:38 AM
OK... Dremel it is. I'm always looking for an excuse to buy a new tool. Thanks y'all...
BillL 03-01-2017 06:56 AM
Don't cut that yet!!! It is a trick . . .
Roy, be sure you double check the edge distance on this before you cut to the print. I had to replace mine, many do.
Flying Canuck 03-01-2017 07:40 AM
I don't think I trimmed mine much because I needed the length for placing the rudder pedal as far aft as possible, I just cut out the lightening holes.
If I had trimmed it, it would have been on my band saw. I can cut .040 easily if I have a reasonably new metal cutting blade. The stock wood cutting blade is useless, but blades are pretty cheap and make a huge difference. It works well enough to cut the thick 3/4" bar stock that's to make the canopy wedge spacer.
The Dremel cut off wheel is a great tool though, I've used it lots. I've got through a lot of sandpaper pieces for the drum attachment, very handy in some of the awkwardly placed and sized openings.
