VAF Forums
-   -   Aerosport Panel Install Video (https://vansairforce.net/community/showthread.php?t=146882)
Jrskygod 02-20-2017 02:13 PM
I have been searching every way I can think of for the aerosport panel install video URL I saw posted in a thread here a month or so ago. Could someone please share that video. It would be most helpful. Thanks
Aerosport1 02-20-2017 02:41 PM
Here are some links to the RV310 panel install
310 Panel link
https://drive.google.com/open?id=0B-...2xwOTRQWndSWDQ
Throttle Console Link
https://youtu.be/tjVtVQIsTVs
Overhead console
https://youtu.be/FNUGjxtQ6RI
Geoff
Jrskygod 02-20-2017 11:26 PM
Thank you, thank you, thank you
edbooth 02-24-2017 08:30 AM
Overhead console
310 Panel link
Overhead console
Geoff
It is possible to install the wiring for the overhead console up through that center brace and get rid if that ugly conduit.
NovaBandit 02-28-2017 10:50 AM
The "ugly conduit" you mention has been completely glassed into the a pillars and have a nicer finished look than the stock design.
You can squeeze whatever you can up the center post, or go under the floor and up into the overhead from the tailcone. I have more wires running to the overhead than I could fit in the center post, AND I kept my antenna wires and power wires separate... hence the "ugly conduit".
tazzrrd 02-28-2017 08:33 PM
Ed, the cables that provide Vans for the quadrant are used to use them in the Quad Arm Rest of Aerosport, as you show it in the video or it is necessary to ask for a special measurement ???
tks
Renzo Rissetto
Rv-10 builder - Chile
rleffler 03-01-2017 06:18 AM
tks
Renzo Rissetto
You'll need longer cables. Once you get the arm rest and quadrant, you'll need to measure the length. There are too many variables to simply state one size fits all.
NovaBandit 03-01-2017 02:42 PM
Yup. What Bob said.
Bill Boyd 01-31-2020 07:01 PM
Help?
I'm at an awkward stage where I have the quad armrest center console but AFS has my 310 and lower panel parts for the next few months. Hoping to move forward with quadrant and console mounting but not sure what fore-aft datum I can use for positioning the arm rest console on the tunnel cover without the lower panel to butt it up against.
Is it safe to go off a measurement from someone else's build? Is there a way to fudge any gap that might result between quad console and lower panel piece with rubber trim? Or am I better off finding other things to do until the lower panel is installed? I probably can't even finish up FWF until I have the quadrant mounted and can measure/order the 3 Cali Push Pull cables to go between...
Maybe a reference distance between the forward-most tunnel cover mounting screw that gets match-drilled common with the console and the console's forward factory edge would suffice.
rleffler 02-01-2020 05:07 AM
I think the answer is, it depends on what you are measuring.
I only have a couple data points, but none of our aircraft are identical. Things can easily be off 1/16? - 1/8?. If you want to ensure a flush, tight fit, I would wait. At the end of the build is not a time to start taking short cuts. You want the cosmetics to look as perfect as you can do them.
For the control cables, being off that same amount isn?t a big deal. If you don?t have your lower console, Geoff should be able to give you close measurements as to where the throttle will be located. Get some weed eater string and run it they way you want and measure it. Adding an inch for insurance shouldn?t be an issue.
There still will be FWF stuff to do once the controls are cabled up.
Out of curiosity, why does AFS have your lower console? I would have thought all they needed were the panel inserts.
