PreKote Question
I have a question about prepping parts with PreKote for priming with SW P60G2 Industrial Wash Primer.
Previously I have been sanding (scuffing) all shiny surfaces with Scotchbrite pads to a dull finish in order to get good adhesion of primer and then washing with Lacquer thinner. Primer sticks great, but all this sanding and washing with lacquer thinner is a bit of a pain. As I read about PreKote, it's not clear to me if I can avoid all this tedious sanding before washing with PreKote. If I simply wash with PreKote and scrub (lather it up) with scotchbrite pad as per instructions, does this properly prep the factory surface without having to sand all the parts to dull finish by hand before wiping down? It's not clear to me from other posts if I can avoid this initial "sanding" of the parts before using PreKote. Can someone give me their insights? |
Hi Randy,
I would suggest using the Prekote at 100% and lathering with a maroon scotchbrite pad. Lacquer thinner isn't necessary as prekote does clean the aluminum oxidation and any light oils. I would suggest that if you have any adhesive contamination that you use goo gone or a solvent on those areas first. This system has been working great for me. The real test was using gorilla tape over the akzo when I was rolling the leading edges. The AKZO held up like a champ. Good luck! |
prep
Two types of adhesion "mechanical" (sanding) and "chemical" (solvent) if the product can "bite" into the substrate with one of those your good to go. With that said do a test of no scuffing leave it sit for manufacture full cure time and see what it takes to scrape it off.( read up on all the manufacture data they do all that testing for you to see) On aluminum I've always abraded the the surface metal prepped than prime just to be safe. I've seen a Cessna 180 K model factory sea plane mod and inside the wings the Zinc primer was coming off in dollar bill size sheets. maybe no prep? Just depends on where your priming I own a 70 year old Cessna with NO PRIMER and inside the air frame looks pretty good.
At the beginning of my build I bought a 5 gallon bucket of PreKote and will use almost all of it for the RV-10. Yes it is tedious and requires some elbow grease but well worth it.
My procedure: 1. Put on Nitrile or Latex gloves and keep them on for entire process (very important as it prevents oil from hands from contaminating parts) 2. Spray product on shiny aluminum 3. Scrub with maroon scotchbrite pad until all shiny aluminum is scuffed and nice gray lather is formed 4. Rinse well and make sure water sheets off nicely (no water beads) 5. Hang parts in paint booth to dry The whole point of PreKote is to eliminate having to use other harmful products...no Alodine, no acetone. I am anti Alodine big time! I highly recommend AKZO two part epoxy primer, the stuff is bulletproof. I have no experience with other primers though. |
Cleanser
Good advise about mechanical, chemical adhesion and removal of Aluminum Oxide.
If you want another option, try the same scrubbing process but use Bon Ami cleanser. It's my choice with P60G2. Low cost and works great. |
I use PreKote and think it works great! I use as directed and spray it on the part, do a scotchbright scrub in one direction, spray it again and go 90 degrees from the first way... then rinse with water and let dry.
The Precoat info says it replaces acid etches and conversion coatings
P60-G2 primer is a self etching primer. It is specifically designed to not require pre-eteching or use of a conversion coating. In my opinion, you would be going to a bunch of extra work and expense using it as a prep for P60. Particularly if you are pre-scuffing all surfaces just before priming. If you were using a nonself etching (epoxy) type primer, then it would probably be a very valuable step. Cleaning the parts well is still important but that can be done with a good wipe down with an inexpensive prep solvent... even colman stove fuel (naptha). |
Since you're scrubbing the aluminum with a scotchbrite pad while you are using the PreKote it will still end up with the same dull finish you get with your current process where you scrub it with the scotchbrite pad before washing. Of course I'm no expert, and have never used PreKote, but I don't see much of a difference in the end result between scuffing before washing vs scuffing while washing with PreKote.
Thanks CES 140 for "mechanical" VS "chemical" etching. Helps me understand it much better.
I get your point, but the first batch of parts I scrubbed with scotchbrite to get dull finish (mechanical etching), then used scotchbrite pad soaked in lacquer thinner to clean, so in affect, we using scotchbrite pad twice. I'm thinking if I can chemically etch parts to that dull gray finish, it will take a lot less "scrubbing" than using the scotchbrite pad alone. Fundamentally, I'm just lazy and looking for the path of least resistance. :) |
| All times are GMT -6. The time now is 09:11 AM. |
