VAF Forums
-   California (https://vansairforce.net/community/forumdisplay.php?f=102)
-   -   Hangar in TOA or CPM (Torrance or Compton) (https://vansairforce.net/community/showthread.php?t=146257)
Piloto506 01-31-2017 10:33 PM
I will have my RV4 in about a month and a half and are looking for someone that would like to share a hangar at either Torrance or Compton airport.
The other option is to rent one. I have the opportunity to rent a hangar at either Torrance or Compton right away as well but again would like to find someone that would be interested in sharing as they are in the $500 monthly range.
Contact me via PM or Text/tel 2139257992
xavierm 02-01-2017 07:51 AM
Cheapest you'll find
CPM has the cheapest hangars you will find in the area. It's a friendly airport and more relaxed than TOA although you can't go wrong based at either airport.
EAA Chapter 96 (AT CPM) has hangar space available which is lower cost.
Meetings are the third Saturday (Feb. 18).
you can find out more about the hangar space here:
http://www.96.eaachapter.org/hangarspace.htm
Piloto506 02-01-2017 10:02 AM
Most definitely. I would love to be in Compton just would like to offset some of the costs by sharing it with another plane. I plan on joining the local chapter as well for sure.
Piloto506 02-04-2017 10:01 AM
Ended up renting a T-hangar at CPM. I will be joining the local chapter as well so that should be fun. I was a member previously but never really active.
The hangar will be empty for a couple of months in case anyone needs a temporary space until I can bring my plane over as it is currently in TX.
Also still looking for anyone interested in sharing preferably a smaller plane, high wing, canard, or ultralight as the hangar is 1,000 sf, 40' wide, 35' deep.
