Intake pipe connection
Good day,
I have an IO 360 With a bit of a loose Intake Pipe Connection. I was hoping someone has a swagging tool (lycoming part 64781) that I could borrow or rent. Alternatively does anyone know of a shop in SE Texas that I might ferry the airplane to for the repair. Thanks Rodney |
Careful cleaning & your choice of flexible sealants works pretty well (for about a decade on one I'm intimately familiar with).
Zephyr engines in Florida rented me theirs when I needed one. The deposit was steep, but was fully refunded when I returned the tool.
Edited to add: Removing the old tube was a bear. Fitting and swedging the new one was easy with the swedging tool. |
Loose sump intake pipe
Several years ago I had a loose sump intake pipe, my engine builder (Aerosport power) said to clean the area very well and to use Green Wicking Locktite. Sorry I don't remember the Locktite part number. This is a common repair for this problem and works very well.
Thank you for the input
Good evening,
We found a source to rent the swagging tool. Should be in Houston tomorrow. Plan on using the green loctite as well. Thank you for the information. Fly safe Rodney |
| All times are GMT -6. The time now is 11:32 AM. |
