Bare Bones Low Cost ADSB-OUT
Members,
My plane is already set up for ADSB-IN with Garmin GDL39 I want a simple OUT solution. I already have a GTN650 that was installed with a new altitude encoder. I am thinking a used GTX330ES would be my easiest solution. Would I need any other hardware? Air/ground switch or any odd stuff like that? thanks |
A Trig TT22 is probably the cheapest and easiest solution. It has a built-in altitude encoder.it can be wired up in about an hour and only needs one wire from an external source besides power and ground. I have never had a problem with one of these, and I have installed a bunch of them.
Or a Freeflight RANGR Lite UAT out only model. It can use your GTN as a WAAS source and has a built-in digital encoder. Will work with legacy or digital Mode C transponders. Right at $2K if you do it yourself.
In fact you could pick up a used Navworx model and run it legally since you have a panel mount WAAS navigator source that negates any proposed AD action. I bet they would be very cheap on the used market right now. Jim |
Another option
If your current transponder is a King 76A you may want to look at the Trig TT31. It has the same dimensions as the 76A and will work with the old transponder's encoder. It does require a squat switch which is about $125 if I recall. John
Pretty disappointing options.
These "cheap bare bones options" aren't very cheap!!! Are we really going to have to spend 2000 minimum to get adsb compliant?
extra characters |
I plan to wait until close to the deadline and aim to spend less than $1k. My Stratux box works great for now (yes, I know it doesn't show all traffic - I use it mainly for wx) for adsb-in. Since I will install myself no need to worry about an avionics shop backlog. Chris |
1/31/2017 I just got an email from above link that said : Hello Dennis, We will be announcing a new product at Sun'N'Fun for use with Experimental and LSA aircraft. Stay tuned! |
Yes you probably are. Don't think I've seen ADS-B Out compliance anywhere below $2000.
| All times are GMT -6. The time now is 02:44 PM. |
