F-1040 Upper Fuse Channels
I just sent the following to the Mother Ship, but you guys are usually faster with a reply:
We?re up to page 29-16 and I have a question about the Upper Fuse Channels. There are three sets of three holes in the upper flange that look like they?re for plate nuts. I can?t find any reference before of after about riveting plate nuts on the channels. However, once the F-1042E Gussets are riveted to the channels, there will no longer be access to the aft-most hole for countersinking for a flush rivet. Did I miss something in the plans? Is something missing in the plans? Are theses for optional accessories? The holes are in the figures on 29-1 and 31-7, but nowhere else where you can see the channels. TIA, Jeff |
Jon,
You're my new hero! Thanks a ton! Jeff |
Install now..
I came across the same head-scratcher. Yes, you want to install the plate nuts now.
| All times are GMT -6. The time now is 02:19 PM. |
