VAF Forums
-   -   RV-9 ride/forward visibility (https://vansairforce.net/community/showthread.php?t=146006)
MarkW 01-31-2017 05:51 AM
OK so I had a little time yesterday so I browsed the web.
Between the FAA, EAA, Jetphotos and Van's I found a few more.
Very large amount in Europe.
My list now has 41 state side and 14 in Europe.
Many on the FAA list as RV-9's had not pictures on the web so I could not verify that they were indeed tailwheels.
I is amazing to me that so many people fly under the radar. No pictures on the web and no flight data. There were probably 20 I could not verify with a picture.
Philippe Michel 01-31-2017 09:58 AM
Mark,
Do you have my 9 in your list? N19MP.
Philippe Michel
alpinelakespilot2000 01-31-2017 11:48 AM
This sounds more accurate, Mark. When I started building in 2005 I had also collected pics of RV-9s. I can't find that folder now, but I'm pretty sure I had at least 8-10 then, so there must be way more now.
Steve
N941WR 01-31-2017 11:52 AM
Mark,
I think Michael Ice's -9 went to South Africa, IIRC.
rvbuilder2002 01-31-2017 12:41 PM
Sounds about right.... When people ask me my guess has always been somewhere between 50 - 70 built as tail draggers.
MarkW 01-31-2017 02:54 PM
Philippe,
I have now added you, thanks.
I found a Tim Donham that thinks his was the first RV-9 N9TD.
His was completed in Jan. 2004. Seems like Van's would have been the first.
I forget, was Van's started as a A then converted or the other way around?
Bill,
I have N119TJ in SA maybe that is it.
rvbuilder2002 01-31-2017 03:17 PM
Originally Posted by MarkW (Post 1146469)
Philippe,
Bill,
The original RV-9 prototype was purpose built as a tail dragger.
First flight was January 2002. No Tail dragger finish kits were sold/shipped prior to its flight testing.
flyrv6a2001 02-01-2017 09:45 AM
I believe N9TD that was the first customer built RV9 to fly.
apkp777 02-01-2017 05:09 PM
I am 6'2 and have to stretch a bit to see clearly. It's on par with other tail wheel airplanes I have flown. I have the Bell style tailwheel which sits a bit taller than the stock Van's one. That helps a bit. You will have no trouble. Just don't assume there is nothing in front of you. You will need to clear the area by stretching or by S-turning.
N941WR 02-01-2017 07:05 PM
Bill,
Nope. Michael's was never an "A" and never had a Subaru up front.
I found this picture of it, during its "transition phase".
