VAF Forums
-   RV-8/8A (https://vansairforce.net/community/forumdisplay.php?f=6)
-   -   Odd wing cuffs (https://vansairforce.net/community/showthread.php?t=145532)
flywray@hotmail.com 01-08-2017 10:16 AM
Odd wing cuffs
I just purchased an RV8, and have several questions. When I learn how to post a picture I will, but there are small wing cuffs attached to the fuselage right at the leading edge of the wing. I have flown other 8s without them. Are they of any use?
skylor 01-08-2017 10:22 AM
Strakes
Do a search for "strakes" here and you will find some information about these. Some have found that they reduce "tail shake" at stall onset and provide a slight reduction in stall speed.
Skylor
Romeo Victor 01-17-2017 08:36 AM
Hi Carl,
I'd like to install my strakes but couldn't find a template. can you gib´ve a hint where and how to position these things?
Regards from Bavaria
Stephan
Mike S 01-17-2017 08:42 AM
Welcome to VAF!
Ray, welcome aboard the good ship VAF.
Questions------you came to the right place for your answers.
Ironflight 01-17-2017 09:21 AM
I haven't heard about RV-8 strakes in years! Way back when, it was common for folks to put them on, but it seemed to be the consensus that the buffet on the tail (that was addressed by the strikes) only occurred to folks that had not yet installed gear leg upper fairings. Once those were installed, folks had no buffet, without the strakes. No one I know ever did a scientific determination of there being a downside to the strakes, but they essentially proved to be unnecessary if you had upper fairings installed.
Just my own experience - no strakes, no tail buffet in the stall, and have always flown with upper farinings.
Paul
Ron RV8 01-17-2017 10:18 AM
Buffet before stall = stall warning...
I get a nice tail buffet about 2 kts before the stall with fairings installed.
I see it as a warning that I am very close to stall and am happy to leave it as is...
DanH 01-17-2017 06:43 PM
Same here, and I too consider it a Good Thing.
mike newall 01-18-2017 10:12 AM
I think this is a crossover from the aerobatic guys.
Things like DR107's had bad buffet at higher G which was reduced by similar strakes.
At our modest operating envelope I doubt they would be of any use other than to mask the upcoming stall which is a bit odd, as others have stated.
oaklandaviator 01-18-2017 12:46 PM
Buffet
I don't have them, but want to install them. Anyone know where to get them? I get a pop of the canopy skirt at about 4 "g" that gets stronger at higher weights. I'm thinking these will stop that.
