Best fuel strainer for RV-12
So I am ready to start putting fuel in the tank for calibration. I will be using premium mogas.
With the 12's unusual fueling opening, and given I will be refueling by myself, is there one "BEST" fuel strainer that takes the worry out of spillage and debris? |
I use a Mr. Funnel to transfer the fuel into a Flo-Fast pump and use that to fill my -12. Is a bit of a pain but works pretty well and I don't have to lift a can to the filler neck. I'd like a better solution but it's the best I've come up with.
I fuel this way... http://www.vansairforce.com/communit...35&postcount=1
I add a full 5 gallons at a time but only after verifying tank will accept that quantity. I use a wooden dip stick with 2 gallon markings to measure tank level. In my opinion the course strainer in the tank and the fine strainer in the gascolator are sufficient to trap all debris. This is verified by visual examination of both carb float bowls at each condition inspection. Bowls have always been perfectly clean... |
so fast with Flo Fast
I second the vote for Flo Fast and the Mr Funnel.
So easy and no splash. Ten turns on the handle per gal of fuel. 90 seconds to transfer 7 gal. |
It's also easy to fabricate yourself. The blue thing is a pump to pressurize the jerrycan. 20l (5,3USG) will take about 3 minutes to transfer. I replaced the hose with a longer one so the jerrycan can stand on the floor. Two 20liters are enough for "day tot day flying" (we don't have mogas at the airport). The transfer kit is relatively cheap and lightweight. The pump can be replaced with a e.g. a footpump or compressed air. |
Double Screen Mr Funnel
Let me add, if you go with the Mr Funnel, get the double screen. The single screen is much too slow.
I use a battery operated fluid pump (Model JB5684) from Northern Tools. It cost less than $20 and runs on 2 D cells. Made by Sierra Tools. Transfers about 6 qts per minute. I got too tired of lifting the jerry cans.
Jerry cans came from Harbor Freight. |
How long do the batteries last?
Additional filter
Fast Flo Wins
Thanks to all who responded. I have purchased the Fast Flow for 5-gallon cans and a Mr. Funnel.
Ken |
Jim, regarding your use of a wooden dipstick. What does this stick look like? I haven't found a dipstick solution that can accommodate the filler neck curve.
George |
Why the stick?
Don't you have a gauge on the top of your tank and a gauge in your instrument panel? If calibrated why use the stick. What am I missing?
I also track time Vs. fuel burn rate to verify fuel quantity displayed on the EMS during flight. Never ran out of fuel... |
If you search you should find another thread on sounding the fuel tank. I use a piece of translucent brake line to sound the tank. The thread includes the measurements for 5, 10 and 20 gal markings. Brake line is flexible enough to accommodate the filler neck bend, but stiff enough to give good readings.
http://www.vansairforce.com/communit...d.php?t=128429 |
| All times are GMT -6. The time now is 12:03 AM. |
